Replace rear steps
agesilaus
OK the rear steps on my unit came to an unfortunate end out in Montana. Now back home I ordered and have here a set of replacement steps. Geez they are very heavy. The old steps seem to be welded in. At least I can detect no bolts.
The new ones came with no instructions and four bolt holes. This is a 24 inch 3 step unit (strom-carlson replacement).
Before I get the angle grinder out and cut the old set off, does anyone have any suggestions? I'm sure I'm not the first to go thru this.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
0 REPLIES 0
