โJun-29-2014 07:20 PM
โJul-08-2014 02:55 PM
jspringator wrote:
Larry, would RainKap be helpful for my application?
http://www.rvaccessorypart.com/page/page/3352092.htm
It would bypass the Jayco Eagle gutter system that has a gutter and a small tube with a slit in it underneath the gutter. I guess the small tube is to collect water that goes over the gutter. My awning is underneath the molding, but I'm not sure there is enough space to mount the RainKap. I guess I could cut it down.
This would address the issue presented by Gjac. I do'k know of any other way to seal the molding unless I covered the entire thing in Eternabond.
โJul-08-2014 11:02 AM
โJul-08-2014 10:42 AM
โJul-03-2014 02:45 PM
โJul-03-2014 01:41 PM
jspringator wrote:
I replaced all the screws in the molding holding down the rubber roof with stainless steel screws dipped in 3M5200.
โJul-01-2014 02:28 PM
โJun-30-2014 06:17 PM
โJun-30-2014 05:57 PM
โJun-30-2014 02:17 PM
โJun-30-2014 01:17 PM
jspringator wrote:
It would if it was leaking around the screw. I also need to make sure the gutters aren't clogged. I think that is what caused the leaks.
โJun-30-2014 09:11 AM
โJun-30-2014 09:06 AM
โJun-30-2014 04:35 AM
โJun-29-2014 10:43 PM
jspringator wrote:
I replaced all the screws in the molding holding down the rubber roof with stainless steel screws dipped in 3M5200. That is a lot of screws!
Do I need to do anything else? Run a bead of sealant at the top of the molding? Cover the entire molding with Eternabond? I can't see either one of these would be an improvement on the crews heavily dipped in 3M5200
About 3/4 of my screws had rusted threads. On mine, a clog in the gutters caused water to rise into the screw area. I can't see that the plastic screw cover does anything but make the moisture hang around longer. My rig just turned 10. I wish I had done this 9 years ago.
