The dinette area has a table, but to create bed space, that table has to be lifted out of the two metal cylinders that support it. It is then placed to form the bottom side of the bed between the two benches. The weight of the table is horrible and it takes two people to lift it. I often go camping solo and would like an idea of what kind of replacement feature could be used instead of the one described. Possibly an automated lowering device or something?
The particle board with laminate does get heavy. We made one out of pine with a nice stain and polyurethane finish. Even put the cup holders in it. You can buy some premade at the home improvement stores and modify to fit
The rv table hinge bracket on this page and the adjustable table leg will put half the weight of the table on the wall. It just depends if the table can be screwed into.
If you have no other bed option, you could build a lighter table but be careful it is sufficiently robust to handle the weight. One inch plywood is where Iโd start. With bracing, maybe 3/4 inch.
