โApr-02-2019 06:37 PM
โApr-07-2019 11:43 AM
โApr-04-2019 07:23 PM
โApr-04-2019 05:46 PM
โApr-04-2019 04:59 PM
โApr-04-2019 03:08 PM
AlwaysDreaming wrote:pauldub wrote:
I bought a check valve to put in the water line but never did install it. I did install a shutoff valve at the shower head and that has totally cured the cold water blast problem. The problem is caused by the water dribbling from the shower head with the built in shutoff that doesn't fully shut off. Just add an inline shut off and all is good and it's easy to do. I bought the KES Shower Head Shut-Off Valve Brass with Metal Handle Polished Chrome K1140B3 from Amazon for about $12.
I have on K1140B3 on order and will try this first, by removing and replacing the dribble valve . If it works, I will return the check valves.
I don't understand why the dribble valve causes the problem, but if replacing it with a shut off works, I don't need to know.
Best Regards, Thanks
โApr-04-2019 12:03 PM
โApr-04-2019 08:48 AM
โApr-03-2019 03:48 PM
AlwaysDreaming wrote:Dutch_12078 wrote:
I installed check valves on our shower feed lines to eliminate the backflow issues that cause the hot/cold blast when the shower head shutoff is used.
Thanks. Where did you install check valves? I assume it doesn't matter where you install them?
โApr-03-2019 12:55 PM
Could be interesting for guests. Do I tell them?
โApr-03-2019 11:41 AM
โApr-03-2019 10:17 AM
โApr-03-2019 09:50 AM
โApr-03-2019 08:33 AM
Old-Biscuit wrote:
Turn shower head against shower wall when turning back on
โApr-03-2019 08:25 AM
