Securing Solar Panels
allen8106
Hey gang, need your inputs. I recently finished the installation of four solar panels on the roof of my 5er. I have 6 aluminum L brackets holding 4 panels framed in 1 1/2 inch aluminum angle. The distance between the aluminum angle and the roof is minimal so it makes inserting a bolt and nut difficult and time consuming. I am considering using these hitch pins like the one in the pic below.
Thoughts?
https://www.zoro.com/fabory-safety-pin-2-wire-snap-u396830310137/i/G1745606/
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
4 REPLIES 4
dons2346
Nut and bolt
allen8106
DrewE wrote:
The main consideration I can see that might be tricky is that the hitch pins provide no support along the length of the fastener, while a bolt and a nut do. That may allow the panels to wiggle sideways more than you want.
My thoughts too.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
memtb
allen, Though a little โ€œafter the fact, go back a bit on Do It Yourself Mods/Upgrades (solar panel upgrade) and see my recent post on solar panel installation...it may give you some options that you may consider.
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
DrewE
Is this going between a bracket mounted on the roof and one on the panel, in lieu of a through bolt?
I'd probably use a cross-drilled stud and a spring cotter pin rather than these, but that's more a personal preference than anything. It may also be possible to attach a captive nut of some sort (welded on or whatever) to one of the brackets so you only have to thread a bolt in from the "easy" side, if there is one.
