water heater drain mod
coolmom42
Visited my son this past weekend and he was watching me fight with the water heater drain plug. He is a mechanical engineer and always tinkering with something... so he said "DON'T have to do that every time you drain it." He got a male NPT to barb fitting, clamped a 3" section of hose on the barb fitting, and clamped the other end of the hose to a small ball valve. It all tucks up out of the way of the door and burner.
Now draining the water heater is just a matter of opening the ball valve.
We also cut some covers for the bins below floor level in the large rear storage area.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
31 REPLIES 31
midnightsadie
I did this 10yrs ago work fine.
garyemunson
Best to keep a plug so when you pull it to drain, you can insert one of the flushing wands to get the sediment out. A lot builds up in them.
