Sep-15-2013 05:33 PM
Sep-19-2013 11:46 PM
Sep-19-2013 11:18 PM
Sep-18-2013 07:58 PM
Sep-18-2013 05:25 PM
Sep-17-2013 01:23 PM
Sep-17-2013 12:50 PM
tenbear wrote:wh33t wrote:
How do you find the LED light vs the incandescent. I see the lumen output of the led panels seems rather low and Im curious how they compare. Your panels specifically seem lower than the 48-5050 panels I was looking at. How do you find your led replacements?
I find the light from the 36-1210 LEDs that I bought very close to the 1141 bulbs they replaced. I also bought some 36-1210 from a different vender and they were much dimmer and much poorer quality, and cheaper.
I guess it depends on your reason for converting to LEDs. I did it to reduce the power consumption. The LED panels I bought draw about 0.2A. The 5050 LED is actually 3 LEDs in the same package, are about 2x as bright and draw about 2x the current. Of course, the current drain depends on the series resistor If the resistor is a higher resistance then the current will be less and the light will not be as bright. All LED panels are NOT created equal.
LEDs are directional. The panels direct most of the light down and while the lumens may be less, the light in the area lit by the LED will be quite bright. Lumens is a measure of the total light from a source. BTW, I don't trust the advertised lumens on eBay.
The only way you will know if a particular light is what you will like is to buy 1 or 2 and try it. There are differences in the fixtures, differences in the series resistors and differences in the LEDs themselves.
Hope this answers your questions.
Sep-17-2013 05:36 AM
Sep-17-2013 03:20 AM
Sep-16-2013 10:12 PM
tenbear wrote:
The fixtures look like plastic so I suspect the bubs are 1141 bulbs. 1156 bulbs get even hotter than the 1141s and can cause damage to plastic fixtures. Mine had 1141 bulbs.
I replaced most of my 1141s with 36-1210 warm white LED panels.
These are the panels I used.
I also used some 18-5050 cob lights but I don't remember who the vender was.
There are considerable differences between lights sold by different venders so buy a couple and see how you like them before buying a lot of them
Sep-16-2013 05:08 AM
Sep-16-2013 05:00 AM
Sep-16-2013 01:40 AM
Sep-16-2013 12:20 AM
wh33t wrote:
Here are some pictures.
Sep-15-2013 10:43 PM
