โJul-13-2015 11:04 AM
โAug-07-2015 11:25 AM
2112 wrote:TXiceman wrote:Cleaning the evaporator from the inside once a year helps as well.
... maintenance of cleaning filters and yearly washing of the coils in the roof top portion...
โAug-07-2015 10:54 AM
โAug-07-2015 08:42 AM
โAug-07-2015 08:14 AM
SH wrote:brokeagainbutnotout wrote:
It was in the open where road crud could hit it. I cleaned it up, etc ... solved the converter and AC problem. It would be a good idea to periodically check the ground, especially if it is exposed to the elements.
Interestingly enough, we came back to our rig after a day trip to find none of the 12V systems working. Grabbed my meter to go out and check the batteries. Burnt my fingers on the ground connection to the battery as well! Connection was loose and a bit dirty. Cleaned and tightened and all was well! These connections are now part of my "pre-flight" before each trip.
โAug-07-2015 07:56 AM
โAug-07-2015 06:55 AM
โJul-14-2015 12:54 PM
โJul-14-2015 07:26 AM
CarlT100 wrote:
Maybe we are supposed to wash and wax our converters and check the oil?
โJul-14-2015 07:05 AM
โJul-13-2015 04:41 PM
โJul-13-2015 04:22 PM
โJul-13-2015 03:51 PM
newman fulltimer wrote:
So in saying it sounds more like a lack of maint which is all on you
โJul-13-2015 12:51 PM
โJul-13-2015 12:31 PM
Brantime wrote:
Not real sure what type of maintenance you do on your converter, or how a compressor going out is a maintenance issue, but if you say so, I am guilty of lack of care? As far as I know, all batteries fail...just a matter of time...but thanks again!
