3-step entry unit broken
kopy_kat
Does anyone know the brand of the 3-step entry steps on a Flagstaff (Forest River)---and where to get a replacement "rivet" for the one that snapped in half on the top step?
Thanks,
Larry
2013 Flagstaff 8528ikws---"Camp MiMiPaPa"
10 REPLIES 10
bigdon68
Stromberg-Carlson makes a direct replacement 4-step. Did it to mine and it worked great.
bigdon68
2017 F450 Lariat Shadow Black / Magnetic, LB, 6.7, Chrome Pkg. TS3 Air Hitch, Retrax, 55 Gal.Aux.Tank
2017 DRV Mobile Suites,induction cooktop, solar, f/b paint, MorRyde IS, 17.5" Tires,residential frig, 3" riser, MorRyde Steps
MY PICTURES
kopy_kat
thanks all--I'll do the bolt with a couple of fender washers for space/sliding application.
Have a Great Turkey Day!
Larry
Duck
ScottG wrote:
Replace the rivet with a nylock nut and bolt so that you don't have to make it tight but it will be loose enough to allow movement.
X2
Don
08-FORD F350 PSD
13 Bighorn 3055RL {For Sale}
rmalik1
flamingstar wrote:
I repaired my broken rivet with a ยผ inch x 1 ยฝ inch long galvanized carriage bolt
After removing the broken rivet I inserted the bolt from the outside of the step/hinge through the plastic spacer and installed a ยผ inch washer and ยผ inch lock nut on the other side. Works perfect.
X2
2012 Cedar Creek 36RE w/ Level Up
B&W Turnover w/ 18k Companion Hitch
08 Ford 350 Lariat DW PSD Crew Cab Long Bed 4:30
ScottG
n7bsn
The steps are all very much the same size.
I've never seen any replacement parts, flamingstar fixed his with a bolt, I fixed mine with a chunk of angle-stock and my welder.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
donn0128
More than likely kwikee. But either should fit.
flamingstar
enblethen
Either a Kwikee step or Stromberg-Carlson
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
sjturbo
Sorry but no. Unless someone does know I would look for Forest River online and call corporate.
