โJan-06-2020 10:25 AM
โJan-08-2020 04:40 AM
โJan-07-2020 03:15 PM
โJan-07-2020 01:02 PM
โJan-07-2020 07:30 AM
โJan-07-2020 06:28 AM
Old-Biscuit wrote:
It is a bolt on or welded on set of brackets that attach to each shakle.
Off set cam plate goes on bracket and is used to align the axles
Park trailer on stragiht level area
Drop a plumb-bob from king pin
Mark surface where plumb-bob points at
Measure distance from Mark to tires both sides
Installation is straight forward and will result in approx 2" taller overall height of trailer
โJan-06-2020 06:29 PM
Second Chance wrote:They no longer install them from the factory. The add on units extend your spring hangers and make it easier to break one as they generate more leverage. There are three factors used to align an RV. Correct Track only deals with one of them. The alignment shop that did my last trailer doesn't use them they leave them alone and just move everything like they always do.
I have experience with it. All the Correct Track system will do is allow you to make sure the axles are parallel with each other and perpendicular to the center-line of the trailer. The system can do nothing about caster, camber or toe. If you have a bent axle or spindle, the only solution is either bending the axle or replacing the axle/spindle unit.
Rob
โJan-06-2020 04:16 PM
โJan-06-2020 01:37 PM
โJan-06-2020 12:39 PM
โJan-06-2020 12:31 PM
