5th Wheel front rail anchored to hat channel only....
Diesel_Camper
Just got done installing a used Husky 15k in my 05 ram 2500. I used a new universal install kit from husky to anchor the rails. The kit comes with 4 anchor brackets and 2 hat channel braces. The instructions specific to my vehicle advised anchoring to the frame on the rear rail with 2 of the brackets and then anchoring the front rail to the hat channel with spacers and the hat channel brackets and then made no mention of the remaining 2 brackets. The instructions for other vehicles do use all 4. So the connection to the frame on the front rail is through the hat Chanel only at this poi t and I have 2 left over brackets. Anyone heard of an install like this?
11 REPLIES 11
Me_Again
R12RTee wrote:
bucky wrote:
What's a hat channel?
That was my question also. I learned something already today and it's only 7 AM.
Hat Channels can also be described as a Roll Formed Metal U-Channel with a bottom horizontal web and 2 vertical legs with outward flanges. These outward flanges can also be called Wings or Fins.
Hats under truck beds would be upside down hats. These are just stamped out of sheet metal, and are the points the bed rest on the truck frame. The flanges are spot welded to the bottom side of the bed. I installed my used Hijacker hitch from my 93 Ram in my 2001.5 Ram and the one rail is center on the hat. I made spaces to go in the hat. Chris
katysdad
sfpcservice wrote:
Just got done installing a used Husky 15k in my 05 ram 2500. I used a new UNIVERSAL INSTALL KIT
Dodge trucks require a custom bracket kit for either 4 bolt or 10 bolt install. You can use either the DRILL or NO DRILL kit.
You can check here: Husky bracket info
The hat rail spacer keeps from crushing the hat rail when tightened down to the frame bracket. You must have all four corners attached to the frame. If not it will tear out of the floor of the truck bed.
In VA a vehicle will not pass safety inspection if:
7. Fifth wheel has any broken, missing, or damaged parts; or is not securely attached to the frame.
8. Trailer king pin is not secure, or is broken or worn so as to prevent secure fit in fifth wheel.
9. Any movement is detected at any location where any device has been placed between the body and the chassis.
(quoted directly from Va State Police Inspection Manual)
Dodge Ram 3500 DRW Diesel
JIMNLIN
We drill/weld Dodge/Ram truck frames even after they went to the hydro formed frame rails in '03 per Dodge Body Builders guide instructions and TSB 13-001-03 dated 2-7-03.
My current '03 Dodge trucks frame mounted hitch brackets were welded into the main frame rails when I bought the truck new per my request. No issues. In fact many upfitters recommend their products to be attached with a solid weld instead of a bolt and nut or frame clamps.
I would use all 4 anchor brackets mounted to the trucks main frame. Then use the spacers if required when attaching the bed rails.
Cummins12V98
Do your self a favor box it up send it back and install a B&W system and forget those bed rails that are in the way all the time.
Their system requires no drilling into the frame. Do not drill the frame!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
2008Wildcat
Pretty sure that the Dodge hydro formed frame wants you to use the U bolt (no drill) brackets also....
They don't want you drilling into the frame for the universal kits.
2013 Columbus 320RS
2011 RAM 3500 Outdoorsman SRW 6.7 Cummins- tweaked!
R12RTee
2021 DRV Mobile Suites 38RSSA
2021 Ram 6.7 HO
bucky
Puma 30RKSS
Racine96
You need the four points of contact.
htowners
katysdad wrote:
what is your TV ?
Doesn't mention bed length, but regardless of that all 4 points need to mount to the frame. I bought the custom mounts for my SB 2500 and had to slightly alter the rear leaf spring frame forward mounts, but it's got "teeth" into the frame.
2008 Tiffin Allegro Bay 38TGB
2005 Saturn Vue
Stella and Luna, our 2 shelter rescues
Diesel_Camper
2005 Dodge Ram 2500 4 door short bed.
katysdad
what is your TV ?
