โJun-05-2016 07:08 AM
โJun-05-2016 07:17 PM
โJun-05-2016 05:53 PM
boshog wrote:Mr_MrsSchlepprock250 wrote:
We currently have a TT so I have to get a 5th wheel hitch for our truck. It's a 99 F250 Superduty CC with a 7.3 diesel and 3.73 rear axle.
One often overlooked feature of a hitch is the ability to adjust not only the fifth wheel height from the truck's bed but also the pin location so the RV's weight sits over the axle and not behind it. This makes it much easier to level your TV and trailer.
I'm not familiar with all the hitches but the B&W Patriot is flexible to hitch plate location. Also you may want to consider a sliding hitch to allow sharper turns without hitting the truck cab to the RV's cap (if you have a 6 foot box). The only sliding hitch I found that allows multi-height adjustments is the Demco Hijacker Autoslide.
Both of these solutions are heavy weight fifth wheel hitches, 200 plus pounds, two people would be needed to remove and replace the hitch in the truck bed. If this is important, then Anderson makes a solution but be aware, your pin weight will ride behind the rear axle and it offers a fixed height.
โJun-05-2016 12:57 PM
โJun-05-2016 12:27 PM
โJun-05-2016 11:44 AM
โJun-05-2016 10:50 AM
csamayfield55 wrote:
There is a reason the Reese hitch is affordable, because it is garbage!! IT is very easy to high hitch them and when you do that you can break and bend the locating block for the dual jaw. When that happens the jaws will start rocking back and forth and cause fatigue in the metal and it will break.
Please take a look at the Andersen Ultimate hitch! That is an amazing hitch and anyone who has used it will tell you how much they love them. Easy in and out of the bed and a rock solid tow. They are priced very affordable also.
If you insist on a standard 5th wheel hitch you can not go wrong with the B&W. Very nice but also very heavy
Chris
โJun-05-2016 10:38 AM
ralphnjoann wrote:
I have a truck similar to yours, a 1996 F250 PSD and my trailer weighs just a little less than the one you own. Check out the Andersen Ultimate. Amazon sells it for $519 with free shipping.
I've been very happy with it, especially the weight, which is about 42 pounds.
The Andersen is fairly new to the market and there are a number of posts here, both pro and con, discussing it. I encourage you to check them out.
โJun-05-2016 10:05 AM
jerem0621 wrote:
The pro series hitch you linked to is a fine and affordable hitch. It's dual jaw design is great and is self latching.
The slider base is one thing I have a bit of an issue with Reese/ProSeries. Other brands of hitches use solid bar stock machined to be a slider rail while the Reese/ProSeries base is a welded hollow tube. It's plenty strong enough but by virtue of design it only has 10 inches of travel...other slider bases such as B&W and Curt give a full foot of sliding...those extra two inches may or may not matter. Just something to consider.
One other plus to the Reese/ProSeries is that it is one of the lightest slider hitches on the market. I believe the shipping weight is around 150 lbs and the Curt and B&W is over 200.
I like the versatility that the above bed rails give... Extra tie off points for securing cargo when hauling stuff while not towing... Add a cheap ProSeries gooseneck plate for your fifth wheel rails and you have a gooseneck hitch and can haul gooseneck trailers if you need too...no gooseneck ball to get stuck in your bed etc etc etc
Thanks!
Jeremiah
โJun-05-2016 09:10 AM
โJun-05-2016 08:36 AM
โJun-05-2016 08:15 AM
โJun-05-2016 08:05 AM
โJun-05-2016 08:03 AM
โJun-05-2016 07:57 AM
โJun-05-2016 07:52 AM
