5th Wheel Slide Problem?
Air_Boss
We have a 33 foot long, 2008 Challenger 5th wheel trailer, with 3 slides which are moved by a Lippert hydraulic system. The slides are not controlled individually but all on the same line. They move out in sequence, 1 (bedroom), 2 (opposing living room), 3 (large living room slide), and retract in the same sequence, 1, 2, 3. After sitting in storage for a few months, and getting ready for a weekend trip, I attempted to open the slides which worked in sequence until #3. It only moved about a foot of its 3 foot travel when it stopped. I retracted all of them and let sit for a couple of minutes and then opened them again. They all extended as they should.
The next day we arrived at our weekend destination and attempted to open the slides. Slides 1 and 2 deployed except slowly and #3 started out, slowly, but stopped about 8 inches from full out. We retracted them and tried again. Same result. We retracted them for another try. Again it stopped about 8โ€ from full out. I then manually pushed it out to full extension while my wife pressed the โ€œslide outโ€ button.
The day of departure they retracted normally. We returned home and opened the slides to clean the unit. All of them worked normally without the slow or sluggish movement as a few days before and fully extended as they should. Iโ€™m scratching my head as to what may be the problem if there is one.
The fluid reservoir is full and I havenโ€™t noticed any fluid leak. We live in Tucson, AZ and traveled to Flagstaff, AZ where the air temperature was about 30 degrees cooler than Tucson that day. I canโ€™t imagine the temperature would affect the operation unless it was below freezing which it wasnโ€™t. The only thing I can zero in on is the pump.
We are planning a summer trip in 4 weeks and I would like to resolve this issue before that. Any thoughts or suggestions?
Thank you.
10 REPLIES 10
Air_Boss
Thank you all for your responses. I'll check out all your sugesstions. Thanks again.
MrVan
These great(NOT) generic RV manuals listing the wrong fluid is consistent with the rest of the manual.
cummins2014
greatwhitenorth69 wrote:
motorcycle jack wrote:
Troubleshooting your hydraulic problem with out testing some functionality of components is next to impossible but I will give you some ideas to check. First, since your unit is a 2008, if you haven't changed the fluid do it. The fluid is a DOT III ATF fluid at any auto store. As the fluid is open to the atmosphere via the chambers fill port it is hydrostatic (absorbs water) which can cause compression in the fluid and pump low pressure. Second there is probably debris in the fluid which can keep valves open allowing leak back. So when it is drained out take a flashlight and look for debris in the bottom. When you've finished refilling and cleaning the debris out, cycle the slides three or four times to remove any air that may be in the system.
DOT 3 is brake fluid not ATF. OP do not fill your system with brake fluid, check with manufacturer on what to use.
Correct some use hydraulic fluid ,some use ATF. My manual said ATF, but it came from the factory with hydraulic fluid, was pretty obvious it was not ATF .
greatwhitenort1
motorcycle_jack
John
"Motorcycle Jack"
Life time Good Sam Member
Blog: My RV
5th Wheel Blog
Full timing isn't "always camping". It's a different life style living in an RV.
GASMAN6674
Lube the slide rams with silicone spray and fully charge your battery. then see if it repeats.
Jim & Debbie England
Do you have Gas? Propane Exceptional Energy
2015 F350 CCLB 6.2L/4:30 Vermilion Red
2020 Cougar 364BHLGone but not forgotten 2012 Ridgeline 34RLT fifth wheel/2012 V27FK V-Cross TT
golf_bears
Even if you are connected to shore power, I believe the slide system still gets it power from the batteries. So I think Old-Biscut is correct with the low battery theory.
filrupmark
I would start by lubricating slide #3 . Then I would check with the factory for proper pump pressure and test the pressure. It may be a little low.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
Air_Boss
Interesting, Old-Biscuit. However, I recall I was plugged in to AC power at the time. But you never know. I'll look into that. Thanks.
Old-Biscuit
Low battery voltage........and poor ground
