โMay-11-2014 02:32 PM
โMay-15-2014 09:06 PM
โMay-15-2014 02:28 AM
patfromnc wrote:
Ok thanks
another dumb question if were hooked to power all the time do we need a battery? When we first got this camper there wasnt a battery so my hubby just put a battery we had in there , i dont how good the battery was . I will have him check and we will get one . We dont plan on going anywhere but you never know we are in florida after all
thanks again yall
โMay-14-2014 02:35 PM
patfromnc wrote:
Ok thanks
thanks again yall
โMay-14-2014 02:25 PM
Veebyes wrote:
Battery load testers are not expensive & are well worth saving the effort of removing batterys & lugging them to a battery shop then lugging them back & reinstalling if nothing is found to be wrong with them.
โMay-14-2014 06:31 AM
โMay-13-2014 09:03 AM
Wadcutter wrote:
Start with the cheapest solutions first.
Check the fluid in the battery. If connected full time it's possible the fluid level has dropped. Low fluid level will cause exactly as you describe.
If that doesn't fix it then pull your battery and take it in where someone in a battery shop can test it. They can quickly tell if a cell is bad.
While converters do go bad it's a lot more likely it's the battery. Converters don't go bad nearly as often as batteries.
โMay-13-2014 05:29 AM
โMay-13-2014 03:55 AM
โMay-12-2014 08:08 PM
โMay-12-2014 07:34 PM
โMay-12-2014 06:17 PM
โMay-11-2014 04:03 PM
โMay-11-2014 03:47 PM
โMay-11-2014 03:08 PM
