adding a heat strip
outnabout
I have a 2013 Montana and I want to install a heat strip in the AC. Can this be done and does anyone know if it might be pre-wired to the thermostat
Craig & Arline
Montana 5er 3402 RL
2006 Silverado 2500HD Duramax
"On the Road Again..."
22 REPLIES 22
johncamtravel
We have the 2013 Montana also. When we ordered the unit they said we
could not get the heat strip or heat pump. So we went with the Fire Place which works very well and is much quieter. It heats the unit
on chilly nights and mornings. We really don't miss the heat strip
or heat pump at all. If you can add a Fire Place in place of a cabinet that might not be a bad idea. Usually there is a cabinet in or around the living room area that you had the option to add the optional Fire Place. The Fire Place has a 1500W heater built in. Or just go with the 1500W heater as others have said. Hope that this helps.
retispcsi
We have two heat pumps and just like the ac they are zoned. They work well and keep us warm.
2015 Mobile Suites 38 RSSA. 2014 Ram CC DRW 4x4 60 gal RDS Aisin 4:10.
DW, Shadow, Remington and Ron. Living the good life till the next one arrives.
pipers_family
We had one for 8 years and loved it. You use the elec you already paid for. It took the chill off. Yes there is some noise like an unvented AC, but for Texas we enjoyed ours.
GrumpyandGrandm
Normally it will require a new control box in the a/c unit itself as well as a new thermostat that has both gas heat and elec heat settings. As mentioned above some do not like the heat strips, but we were happy when we had them in our MH.
Grandma in front of her retirement home..
She lets Grumpy drive!!
old_guy
I put one in one of my TT's and found they don't work all that well. even on low speed the A/C moves too much air to have any beneficial effect. you just feel all the time. for what they charge you for one you are better off buying two little ceramic heaters and use them.
kennethwooster
We installed a second A/C in the bed room with heat strip. I agree with posts above it is noisy, and moves too much air. It's ok we we leave and leave it running. It's warm when we return. We use small electric heaters. Always remember need some regular house heat to keep underbelly warm. I've also used a light bulb in underbelly just for insurance.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
rv2go
I had a heat strip in the air conditioner of a previous RV. I really did not like it. Too much air flow for the amount of heat. I found that a small 1500watt portable heater worked much better.
Newer units may be better.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
sch911
Since Montana didn't manufacture the A/C unit we'll need to know which brand/model of A/C unit you have?
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
