May-05-2018 04:30 AM
May-05-2018 12:26 PM
BarneyS wrote:jstar wrote:
I have an 03 F250 club cab Lariat with long bed and the infamous 7.3L diesel with 85k original miles on it. Snip...
Why do you say "infamous"? That engine is probably the best one Ford ever made! I had one in a '02 F250 that took us over 350,000 miles with no problems whatsoever and was still running great when I traded it in two years ago.
I even had it running with a tuner for increased HP and torque for half of its' life. I would call it the "famous" 7.3L diesel! 🙂
Barney
May-05-2018 07:39 AM
May-05-2018 07:19 AM
May-05-2018 07:11 AM
May-05-2018 05:25 AM
JIMNLIN wrote:
No problems with a AT tire on the truck but for towing and hauling duties those 1" taller tire may be a power killer for a stock 7.3.....tires weight and diameter. And much depends on your expectations from the 7.3 PSD.
May-05-2018 05:23 AM
Toolguy5 wrote:
I ran Goodyear Wranglers All Terrain on my 2006 towing a Chaparral a little heavier then your Ditchmen. Never a problem.
May-05-2018 05:20 AM
May-05-2018 05:18 AM
jstar wrote:
I have an 03 F250 club cab Laramie with long bed and the infamous 7.3L diesel with 85k original miles on it. I just purchased a 2017 Dutchmen Denali that weighs about 10k dry. My truck has the original 16 inch wheels and older dry rotted tires. I purchased some Mayhem aftermarket wheels in 18 inch as the 16 just seem too dang small. The tires I have now are 265 75 16 and I want to go with 305 65 18 tires which will be exactly the same size sidewall but a little wider by an inch and since the wheels are 2 inches taller so will the whole wheel/tire setup giveing my truck a 1 inch lift. My question is I know I need an E rated tire for the heavy towing I will be doing but what experience do any of you have running an all terrain tire. Will they overheat etc? Should I not get an all terrain tire? I would love some experienced input. Thanks for any help.
May-05-2018 05:06 AM
May-05-2018 05:00 AM
Busdriver
2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
