โMar-08-2016 09:32 AM
โMar-13-2016 06:11 PM
โMar-13-2016 03:14 PM
jerem0621 wrote:
Here is that post on the Cummins forum that details and and shows the damaged Andersen.
Link
Thanks!
Jeremiah
โMar-13-2016 03:00 PM
โMar-13-2016 02:57 PM
โMar-13-2016 02:25 PM
โMar-11-2016 07:13 AM
e-light wrote:
Andersen is simply researching and improving a great product. Search the web for failures of their Ultimate 5er. There aren't any...
If installed properly and used within it's limits I'm sure it's just like anything else. There's no magic or snake oil with the design. It's rather simple...and it works.
5th wheel hitches are great too, obviously. For me I just find the Andersen so much easier and that's why I chose it. And I've driven the heck out of mine. One time I drove an entire first leg of the trip and forgot to lock the ball. I use chains and I use a checklist and somehow I missed it. Anyway I would have never noticed if I didn't check it every time I stop for fuel. I have heard others say the same thing. With 1800 lbs pushing down on the ball I guess it don't move a whole lot. I was mortified when I saw it, but it happened. I f'd up. Thank the Lord no one was hurt or worse. Now I have my wife go back and "peer review" my checklist when I'm finished.
At any rate, the new design looks cool. I see no reason to change as my current Andersen is well under it's rated limits. The new design looks like it could handle much more weight.
โMar-11-2016 12:31 AM
โMar-10-2016 01:06 PM
Cummins12V98 wrote:IdaD wrote:
A slider won't work with the kingpin on my trailer. Also I have the rail mount version so I won't get any bed deflection - the rails are mounted on brackets under the bed which are bolted directly to the frame. It's a very solid setup.
I wonder if they have any plans to make a hitch that mounts to the RAM factory pucks.
โMar-10-2016 07:33 AM
โMar-10-2016 05:16 AM
IdaD wrote:
I like a gooseneck ball on rough terrain. Nice and flexible and no issues hitching or unhitching at an angle. :B
โMar-09-2016 05:38 PM
โMar-09-2016 04:59 PM
Me Again wrote:
Have you ever heard of a 5th wheel king pin crystallizing and failing?
Crystallized balls do happen!
However different strokes for different folks!
Chris
โMar-09-2016 07:50 AM
โMar-09-2016 07:29 AM
IdaD wrote:RustyJC wrote:
Let me answer you this way....if ball hitches (including goosenecks) are superior, why aren't they used instead of 5th wheel (kingpin) hitches on Class 8 over-the-road tractor/trailers? Even those rigs towing double use pintle hitches to connect the dolly to the front trailer. As far as the implied integrity of the hitching arrangements, notice that safety chains are not required on kingpin-type hitches but are by some states on all ball hitches.
If you want to get into the design specifics, we can wade off into that discussion another time.
Rusty
Safety chains are required on ball setups because there are more opportunities for error, not because they're inherently weaker. Wrong size ball or failure to lock the hitch and you could have an issue, whereas a kingpin is a kingpin and it locks in automatically.
I like a gooseneck ball on rough terrain. Nice and flexible and no issues hitching or unhitching at an angle. Not an issue in Texas where you can stand on a tuna can and see 20 miles, but it can be important out west. :B
โMar-09-2016 07:06 AM
N-Trouble wrote:Cummins12V98 wrote:N-Trouble wrote:
What does locking the RV to the hitch accomplish?
It will keep someone from pulling the handle and have the possibility of the RV disconnecting from the hitch. Yes it can and has happened.
Do you ever look in your rearview mirror while towing? Its right there... Might be a concern with a traditional 5er hitch that would just slide off, but its not like its going to jump off the ball without some serious effort.
On the other hand someone could just as easily pull the latch on my B&W Turnoverball so kind of defeats the purpose of having a lock on the Andersen anyways:P
