โAug-20-2014 07:02 PM
โAug-26-2014 06:17 AM
glazier wrote:jerem0621 wrote:
This Guy had his bed broke by the flex in his 18k Companion.
I am not crazy about the adaptor part of the Companion, Andersen, or the Bull Dog fifth wheel adaptor hitches...however, there are millions of miles and hundreds of thousands of users with these products.
You can even add the Curt X5 adaptor base rails to this bunch. These all distribute some weight to the bed floor.
I know they work, I don't think they are unsafe...at all... But the flex may damage some peoples bed to one degree or another...or it may not.
I don't hate the fifth wheel rails...if I were installing a fiver hitch...I would probably use the rails. They just seem more secure giving a firm wide base with four anchor points directly on the frame. My dad has the rails and I can't say the get in the way of using the bed. My best friend had rails in his last truck. I helped him load many things in and out of the bed. The rails never seemed to get in the way.
What I would probably do is install the fifth wheel rails and get a gooseneck plate for my rails if I ever needed to pull a gooseneck. I understand the desire for a "clean bed" but the reality is that most beds are not "clean" with or without the rails.
I know a man who owns a 2012 F250 XL and pulls a fiver.... He has fifth wheel rails...he also has a B&W turnover ball for his horse trailer...I kinda scratch my head on that one...I would do one or the other. $125 gooseneck plate for the rails would have solved the issue.
Thanks!
Jeremiah
The guy in the video stated he installed flat bar in the low part of the bed floor ( he had an older design). B&W provides a part that does just that on all Companion hitches now. With the flats of a bed supporting the weight directly over the bed channels, the Companion is a very strong secure hitch.
โAug-26-2014 04:47 AM
Thanks!
Jeremiah
โAug-25-2014 09:58 PM
Me Again wrote:rhagfo wrote:Me Again wrote:
Anderson really hedges on the requirement for safety chains! I would get tired along with my front jacks with the extra lifting to couple or uncouple it. Trailer has to be lifted and extra 3 or 4"!
I would like to see one after a wreck? Compress test is testing it in a single direction at it's strongest point.
Like the B&W Companion I am not convinced placing hitch loads on sheet metal beds is the best long term design!
Traditional 5th wheel hitches when correctly installed put the load on the frame rails.
If I get a new RAM it will have factory prep and a four puck hitch that locks onto the frame.
Chris
Me Again, could not agree with you more!! I believe that both B&W and Anderson have had issues with bending the bed floor.
Sorry, but for all the bad press, I am convinced that my Reese 16K twin jaw hitch is a great hitch. That especially when I have towed my fiver over 30 miles, with the locking latch in the unlocked position!
Solidly connected to the frame at four locations!!
Sorry Cummins9812V, I may someday think about the rail mounted Patriot, but not one that depends on the sheet metal bed floor.
Well, Russ there are a lot of koolaiders that think the turnover ball is carrying the weight. If you read the Anderson reply, like the safety chains they did not really answer my question. So keep the 5th wheel on the lighter side to protect your bed.
Chris
โAug-25-2014 07:45 PM
โAug-25-2014 06:59 PM
Chris
โAug-25-2014 06:09 PM
rhagfo wrote:Yeah, I don't blame you, I sure would not rely on anything that uses the bed as support. Which is why I have the B&W Companion hitch.Me Again wrote:
Chris
โAug-25-2014 06:08 PM
Me Again wrote:Have you ever even seen a B&W hitch in operation?fj12ryder wrote:
Probably not an issue because the weight of the 5th wheel is not carried on the bed. Most of the weight is transferred through the pin to the frame members.
If you're were carrying the full weight of a large, heavy 5th wheel in the bed only, you'd have some serious denting issues, not to mention probable failure of the bed in several places.
Guess what that is how a B&W Companion and Anderson hitch works, the pin weight is on the floor of the bed not the turnover ball. Some of you need to go back to school!
Watch this video. The pin goes under the shoulder of the gooseneck ball, and then the bolt is tighten, pulling the high down the the bed floor. If it gets compress enough the pin will just move away from the shoulder of the ball. Very simple process with nothing to transfer downward weight to the ball. B&W works in a similar fashon.
http://www.andersenhitches.com/Catalog/ultimate-5th-wheel-connection.aspx
Chris
โAug-25-2014 04:58 PM
Chris
โAug-25-2014 03:37 PM
โAug-25-2014 01:52 PM
โAug-25-2014 01:02 PM
โAug-24-2014 04:10 PM
jus2shy wrote:
I agree with Me Again in the theory of how these gooseneck mounted hitches work in the bed of a truck. That's also the reason why B&W does not advise using the Reese "Sidewinder" with their gooseneck-based 5th wheel hitching system. However, there's no caution for the hitches that utilize the rails or the OEM "Puck" mounting systems. It's just too much torsional force on the goose neck shank when presented with the additional leverage arm of the sidewinder and certain conditions could lighten the hitch from the bed causing excessive twisting and not enough clamp load to keep the hitch oriented correctly. For every force, there's an equal and opposite force. So as you pull up the slack from the gooseneck ball which is being pulled-up from the truck, the hitch (B&W or Andersen) is pushing down onto the truck's bed which is building a clamping force. So the square gooseneck shank coupled with the friction of the hitch base and bed are what prevents it from spinning.
There is only 1 concern I have with the Andersen vs. the B&W Companion. B&W added extra material on their companion hitch to take into account the bed ribs (for lack of a better term), so it doesn't flatten the higher standing portions of the bed with the lower portions. The Andersen doesn't seem to take that into account. I would be concerned over slowly flattening the bed with a loaded hitch. Has Andersen addressed this possible issue?
Also, I'm thinking about adding the Ram's "Puck" system to my truck since it can be retrofitted. Seems like this would open me up to using the sidewinder hitching system which I think would be a home run since that would give me a full 90* turning radius regardless of the trailer nose. Still weighing my options personally.
And in case people don't believe me regarding the tortional force, here it is straight from the horse's mouth.
And in case other RAM owners are curious, appears that the mopar part number for an after-the-fact 5th wheel prep install is 82213665AB.
โAug-24-2014 02:06 PM
โAug-24-2014 10:55 AM
stewks wrote:
I was able to rotate the Andersen hitch around to get the best clearance (about like a no slide hitch).
โAug-22-2014 07:29 PM
