Oct-08-2015 10:35 AM
Oct-09-2015 09:33 PM
Cummins12V98 wrote:up2nogood wrote:Cummins12V98 wrote:Sport45 wrote:
Old news.
The biggest issue I see is Andersen hasn't updated their video instructions to include the new steps. This may be a problem since so many don't read instructions.
This concern may not be limited to the Andersen hitch. B&W has a popular hitch that mounts to the bed in a similar fashion.
B&W has addressed the issue of bed filex with the updated 20K Companion. They also updated the 18K that would deflect the bed when towing heavy like I was.
So I won't mention the bed flex with the Andersen because my last feeling was hurt a while back when mention the bed flex. :B
Go read the 23 page thread on the Cummins forum, might ease you ,and Me Again's mind on something you both will never own.
I don't do the Cummins Forum since someone has my handle.
Oct-09-2015 05:48 PM
Oct-09-2015 05:21 PM
Oct-09-2015 03:25 PM
Learjet wrote:
I'm liking my bed rails more and more...since I don't care or need a flat bed when the hitch is removed. I used the Curt custom brackes with a heavy plate bolted to the frame on each side with 3 large bolts. Then the plates meet under the bed rails and support the rails with the spacers so the bed doesn't crush. Very robust design.
underneath the bed rail pictures. If you look closely you can see the top spacers
Oct-09-2015 03:10 PM
Old news.
Oct-09-2015 03:08 PM
ranchertx wrote:
I use the Anderson hitch with my Mobile Suite and Ram truck and have for 2 1/2 years. I use a rubber bed mat. I have never had any trouble like the op refers to. The hitch is above several frame cross members and I dont see the sheet metal flexing.
Oct-09-2015 02:24 PM
Oct-09-2015 01:53 PM
Oct-09-2015 01:39 PM
Old news.
Oct-09-2015 01:13 PM
Oct-09-2015 04:35 AM
Oct-08-2015 09:30 PM
Sport45 wrote:
Old news.
Oct-08-2015 07:52 PM
Me Again wrote:
The real question is the pickup bed constructed to handle thousands of lbs of weight in consencrated points in the bed without deforming it? I believe the answer from the truck manufacturers would say no. Stating the bed is just sheet metal that was not designed for such service. If you dent it, then that is the users fault not theirs.
There have been many misconceptions posted here including that the gooseneck hitch holds up the weight, when it is used to pull the hitch frame down on the sheet metal bed floor. Chris
Oct-08-2015 07:08 PM
Oct-08-2015 07:06 PM
