Mar-15-2019 04:34 PM
Mar-22-2019 06:22 PM
Mar-22-2019 01:54 PM
opnspaces wrote:
It's actually not that crappy a job if you plan through it. It's even easier if you have a way to dump at home. Find a way to access the valve and look to see which side of the tank it is mounted to.
- Figure out how to tilt the trailer using the jacks or leveling blocks on only one side so the everything flows toward the valve.
- Drain the tank and give it an extra 5 minutes to drip dry.
- Close the valve and reposition the jacks or blocks to tilt the trailer the opposite direction.
- Get some disposable gloves and a new valve.
- Crawl under and look at the whole drain path.
- Loosen but don't remove some downstream hangers to allow some movement in the piping.
- Pull the 4 bolts.
- There should be only a few drops of liquid coming out of the open joint.
- Remove the old valve and make sure you also remove the o-rings (1 per side of the valve).
- Replace with a new valve making sure to use the new o-rings that came with it.
- put the bolts back in and tighten them up.
- Tighten the downstream hangers.
- If necessary use a paper towel to wipe up the few drops that landed on the ground.
Mar-18-2019 04:41 PM
Mar-18-2019 02:30 PM
Mar-18-2019 10:33 AM
Rvpapa wrote:
... find somebody else to work on your rig.
Art.
Mar-16-2019 10:59 AM
C Schomer wrote:
It looks like a pipe stub is glued to the valve and the stub is clamped into the neck on the tank so it can slide out after loosening the clamp. Even if that isn't so, it doesn't matter... It doesn't need to come apart there anyway. Take the four bolts out and replace the center section. Craig
Mar-16-2019 10:43 AM
Mar-16-2019 10:09 AM
Mar-16-2019 05:18 AM
Mar-16-2019 04:31 AM
Njmurvin wrote:Yes.
Does that mean you can take off the 4 bolts and slide the valve body out without cutting the pipe on the outboard side?
Mar-15-2019 06:55 PM
Mar-15-2019 06:45 PM
Mar-15-2019 05:37 PM
Mar-15-2019 05:26 PM
