B&W fail or Operator Error?
shadows4
Not my truck, trailer or hitch. Buddy of mine had this happen to him a couple of weeks ago. Said he did a pull test, all was good. When he pulled out of the campsite it disconnected. I do not have anymore pics than what are shown here. I think he must have missed the second hole when he pinned it. He has had this setup for about 4 years without a problem. He did hook it back up and drove 3 1/2 hrs to the next campground. What are your thoughts?
2016 4X4 F350,CC,SB,Lariat,6.7L diesel,
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
34 REPLIES 34
thomas201
No one has yet mentioned a flashlight. Drag your lazy carcass out of the cab and really look. I spent a day jacking and cribbing 50,000 pounds of trailer and grease that a driver dropped 2 miles from the shop on an interstate in Baltimore. He completely submarined the 5th wheel, the marks showed the pin was in front of the 5th wheel.
Cause for dismissal where I worked.
TXiceman
Walaby wrote:
I have an Andersen, and I suspect over a rough road, it could jump the ball if not locked. Not likely with 3000+ pounds on the pin, but I've been on some roads where I've thought "hope I locked that hitch".
Anything's possible, and eventually there will be that one...
Mike
A goose neck ball can come off the ball. I have seen a couple of goose neck hitches jump the ball when turning into a drive with a good dip. Could just as well happen to an Andersen.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
TXiceman
Fulltimer50 wrote:
I dont understand some peoples obsession with not using proper procedures or included safety features. The pin in the handles is there for a reason why not us it? Is it soooo hard to do a pull test?
100% agreed. We use a Trailer Saver TS 3 hitch with the Holland-Binkley hitch head, and it is very positive and nearly foolproof hitch. But I still lock the lever, visually confirm the jaws are set and the pin is captured and then a tug test.
Ken
Thermoguy
Looks like the tailgate took all the damage to the truck - he got really lucky.
Too bad we can't see if the jaws are open or closed. With the B&W the action of backing in closes the jaws. If you then open the handle, they will come open once force is on them, like driving away. This is part of the disconnect process. If he opened the jaws, then closed them, I suspect they would open. Even if you put the pin in, I think it might open. I don't plan to test this, but that might be where he went wrong.
cummins2014
Mike
I am sure there will be , or already has been . Just like there are probably B&W hitches that have broke or failed , just because we haven't heard of one doesn't mean it hasn't happened .
I believe I did read of one Andersen owner discovering he had failed to lock it when he got to his destination . I have to believe its been done more then once , but yes there will be that one .
Walaby
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
cummins2014
MFL wrote:
Of course you should pin the B&W handle, or better yet use a padlock, so someone cannot pull the pin!
John's buddy...the rig in pictures, stated he did a pull test. The pull test failed to save him from this disaster!
On hitch pictured, a visual test would have alerted him, that something is not right. Handle not closed properly? A gap between hitch head and pinbox? Jaws not full wrapped around pin? East to SEE, if you understand how this hitch works.
Some folks are more mechanically minded than others, but knowing and understanding how YOUR hitch works, no matter the brand, adds much to the safe hookup of any hitch.
Jerry
IMO there has been so much hype about NOT being able drop a fifth wheel with a B&W , its done a disservice to some . Here is a good example ,they all can drop a fifth wheel , except a Andersen . Yes I have read where they have not locked the hitch ,but have yet to read where one has jumped the ball .
JIMNLIN
Likes to tow wrote:
B&W hitches are very good but if you don't get the handle all the way back and pin it correctly this can happen. Also if you get the kingpin over the jaws this can happen. A pull test should have caught this. Now I'm worried about my B&W pulling a trick like this!!
Depends on how hard the pull test was done.
As Jerry mentioned any brand hitch can drop the trailer if the jaws weren't closed around the pin..... or was high hitched.
Even a semi with a heavy loaded trailer may pass a light pull test but usually the first turn slides off the hitch plate ....if the operator did a visual he would have seen the high pin or the jaws not around the pin. A proper visual requires getting out of the truck and look at hitch opening from the rear.
Sounds like a typical rv operator error when the proper steps aren't done.
I wouldn't worry about the hitch failing....just worry about not following instructions from the pros/hitch mfg.
CaLBaR
fj12ryder wrote:
The handle doesn't need to be pinned if it's in place. When you hook up, and the handle comes all the way back, the hitch is secure. You can pull out and the trailer will not come loose, even if you haven't pinned the handle.
You cannot put the kingpin over the jaws, unless you're blind. If you can't see a couple inches of clearance above the hitch head, then you probably should give up driving. ๐Ÿ™‚
This was operator error, pure and simple. I read about one guy that dropped his trailer with a B&W hitch, and it turns out he had pinned the hitch jaws open and forgot to remove the pin when hooking up. The jaws didn't close, the handle didn't move, and he still pulled out.
The guy just messed up. Happens to the best of us.
New to fifth wheels and I can confirm you don't need to pin the handle. Been there done that and it won't happen again. Towed 3 hours to the next fuel stop when I did my stop check and just about @#$ myself that this happened to me, but it did and fortunately nothing really horrible happened.
All this seems like operator error to me too. I do visual and pull check just to be sure and still can't figure out how I missed the pin.
Rob
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
rhagfo
Well likely didn't get the pin fully seated, and didn't do a VISUAL check to make sure the pin was fully seated in the jaws. It is stated that he did a pull test, but maybe not hard enough.
MFL
Nomad II
Nomad II
Jerry
Fulltimer50
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
fj12ryder
MFL wrote:
Ha...your B&W is not capable of "pulling a trick" on you. It's like saying "who stole my glasses" when you don't remember where you put them.
Someone played a trick on you, took your keys, when you left them in your jacket pocket.
Yup, I've been there! ๐Ÿ™‚
Also I agree, by design of the B&W cam action jaws, you likely don't need the pin in handle, to tow your FW. It's kind of a Chinese handcuff thing, the harder you pull on the jaws, when fully wrapped around the pin, the tighter they hang on! Do I recommend trying this....nope!
Jerry
Yeah, not a good idea to do it on purpose. But it has happened, and that person drove about a mile down the road out of the campground before he was informed he hadn't pinned the lever closed. But it wasn't me. ๐Ÿ™‚
Howard and Peggy
"Don't Panic"
Yup, Operator Error..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
MFL
Nomad II
Nomad II
Jerry
