Battery disconnect
Campinfan
I did not want to hijack another thread so I am posing this question here. I just got a new fiver and the disconnect switch only disconnects some things...like the lights. Since I do not want to fry my battery when I am parked at home and hooked to electricity, should I add another disconnect on the positive side? I am thinking that will prevent my battery from overcharging. I know I need to keep checking the water level but you know how busy things get with 3 kids, I am worried I will forget and cook the battery.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
8 REPLIES 8
Allworth
Now, don't be too harsh on dealers.
They only lie when their mouths are moving.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
Campinfan
Thanks for the assurances. I have heard so much about overcharging and "cooking" the battery that I wanted to make sure I wasn't missing anything. My dealer said not to worry but I know that dealers do not always tell you the right info.
bfast54
Agree,the age of your rig,unless low end ..budget rig....should have a Smart type charger.
Monitor the water levels......if it starts using a lot of water,batts get warm.....go further,but,should not need to......
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller:B
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
john_bet
They must have changed the way converter work since '05. Mine is plugged in all the time and I have yet to cook my original battery. My converter is a 55 amp IOTA. I add a little water every spring and press on.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
GON2SKI
I added a second disconnect ( a knife switch) at the neg on lower T105 6V battery as in storage the draining features caused two dead batts.
2014 Arctic Fox 27-5L 5.5 Onan propane, 4pt AutoLevel, RearCam, Central Vacuum Bridgestone R250's tires
2002 F350 Power Stroke Diesel 4x4 CC SRW SB Chipped, Toyo Tuff HT tires
DW and 2 Bull Terriers
Here For A Good Time.... Not For A Long Time
RoyF
My converter maintains fully charged battery at 13.2 volts, which (I believe) is not a "cooking" voltage. I wouldn't worry unless you are measuring higher voltage, say in the 14s.
downtheroad
More than likely you have a 3 stage converter.. It has a 'float' stage that will maintain your batts without overcharging (boiling) them. Once your batts are fully charged, the converter will go into the 'float' mode automatically and maintain a full charge state.
As you said, continue to monitor the water level. But, that's all you need to do.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Bumpyroad
I just put my RV on a timer and have it come on a hour or so a day.
bumpy
