Bed Rail Clearance?
BurbMan
I grabbed a quick measurement from our new 5er (2008 Heartland Big Country) and it was 59" from the bottom of the front portion of the body to the ground. That's measurement "D" in this picture.
The trailer looked like it was sitting fairly level but I had no way to check that at the time so this measurement could be off.
Now I measured from the ground to the top of the side of the bed on my 2015 Ram 3500 and I get 57 1/2", measurement "C". That's only 1-1/2" of clearance between the truck and 5er.
The trailer didn't have a pin box on it when I saw it so I don't have measurement "A". It's now got a brand new Rota Flex pin box on it. I just got a Trailer Saver air hitch, but don't have it installed yet so I don't have measurement "B" yet either.
How much clearance should I have between C and D to be sure I'm OK on inclines, bumpy roads, etc?
15 REPLIES 15
Lantley
I did the correct trax kit as well to gain 2".
Correct trax and taller tires resolved my issue for the mopst part.
But my driveway is on an incline so I need to be careful how turn as I exit and enter the driveway
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
BakFlip,RVLock,5500 Onan LP,Prog.50A surge,Hughes autoformer
Porta Bote 8.0 Nissan,Sailun S637
Correct Trax,Splendide
Durb
I think you are going to be fine. You have 1 1/2" to start with, and the truck will squat 2". Towing an inch nose high isn't going to be a killer. You also have the added advantage of an air hitch if your clearance is is less than 6". Say you are backing tight up an incline and the front of the 5er wants to lean into the bed. Just get out and air up the hitch to give you an extra 2" of clearance. Just as easy as dealing with a sliding hitch.
When towing, the bouncing of the trailer and the give of the Trailer Saver will not threaten your bed rails. Maybe 3/4" of movement.
Cummins12V98
It's really simple follow the method I mentioned. Once hooked up then determine if the RV is setting level or not. If nose low raise the hitch. If nose high raise the RV. Simple math, don't make hot complicated!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
BurbMan wrote:
OK I see what you mean. But is there a minimum that D-C should be?
I said: " This will give you the 6" needed for bed clearance. B & C are irrelevant."
RoyF
The clearance over bed rails is going to depend on your hitch. I bought a 2021 Ford F350 in 2021 with a factory installed Reese hitch. I found that I needed to raise the hitch to its highest setting. (The Reese owner's manual explained how to do that -- remove some bolts, move the top part of the hitch up to align with higher holes, re-torque the bolts.) Now I have six-inch clearance.
I don't know which hitch brands have the greatest height above the truck bed, but that's what we need to get clearance.
BurbMan wrote:
Geez I hope not...I'm going to try and get up to the trailer and get some more measurements today. The problem is not unfixable by any means, if I have to put a lift kit on the trailer axles, that's what I'll do.
I added this Correct Track Alignment Kit to the TT get the 2" lift I needed to run 16" LT tires. Not the worst thing to go thru the suspension and put in new equalizers, bushings, shackles, etc.
You can always "FLIP" the trailer axles...If you do that, you will need to verify your HIGHEST point BEFORE you flip.... That will raise the trailer.. lots of info on flipping RV axles online...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
BurbMan
Roger10378
You are going to have major problems trying to make this combination work. Back when the trailer was made the trucks were 6 inches shorter than the new ones are. I saw a post a few months ago from someone that canceled the order on a new F350 when he discovered how much higher the new ones are vs the older ones. I was thinking about a new truck but the only way I could make it work was either raise the trailer several inches or put a flat bed on the truck. I have opted to have my truck restored because I didn't like the other options.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
BurbMan
rhagfo wrote:
That hitch may be a bit of overkill for a 14,000# GVWR , and will eat up a bunch of your payload.
There are a few different models, I got the BD3 rated at 18,000 GVWR and 3500 pin weight. I thought it would be a good idea to have a little margin, they way things have been going who knows how long we'll have this trailer? LOL... Anyway, Hensley says it weighs 160 lbs which I though was in the range of most hitches.
Lantley
I consider 6" of bedrail clearance the minimum amount required.
7"-8"is preferred. Generally traveling down the road is not the issue.
It's turning into or out of an incline that creates issues.
valhalla360
Nomad III
Nomad III
Do your measurements while hooked up with the landing gear retracted. Otherwise, the compression of the rear truck axle and the exact levelness of the trailer can easily throw your calculations off by a few inches.
Now you just have to measure from trailer overhang to truck bed rails. (this assumes the trailer is sitting pretty much level and the truck is not squatting an excessive amount)
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
time2roll
I believe 6" is considered a minimum. Also consider C for the loaded truck rather than empty.
This is the formula shown in your pic to need 6" but add 2" for rear squat of the truck.
Roads in general are fine. It is the driveway entrances etc that may come close.
rhagfo
Well first of all unless you have the Ram air ride, your Ram 3500 will squat some. It seems to me that my 2016 squats a bit more than the old 2001 2500, the 2016 also rides better. You need to find out how much the hitch will move vertically as that will have an effect.
That hitch may be a bit of overkill for a 14,000# GVWR , and will eat up a bunch of your zpayload.
BurbMan
