โJul-08-2018 05:00 PM
โJul-28-2018 12:01 PM
WrightOn wrote:
Update: I started with the most obvious - hydraulic fluid check and lubing the mechanism - but to no avail. Just before I broke down and called the dealer for an appointment, I decided to get the ladder out and give the slide topper a good check. A-ha! the slide topper was catching against the fiberglass and not allowing it to roll out properly. Somehow, a combination of a slight bend in the roller and a bow in the fiberglass eliminated the 1" clearance and created the drag.
I will combat this issue by taking out the screws that anchor the toppers to the slide (one by one since it is spring loaded) and placing a few stainless steel washers behind the bracket to create additional space.
I will post a picture of before and after in a week or two when I have time to work on it.
โJul-18-2018 05:07 PM
โJul-15-2018 06:08 PM
TXiceman wrote:
Try waxing the sides and bottom of the slide.
Ken
โJul-15-2018 04:03 PM
โJul-15-2018 09:52 AM
โJul-15-2018 09:44 AM
โJul-09-2018 09:37 PM
AlaskaShooter wrote:
Is your slide electric or hydraulic? We have both on our 5th wheel. Bedroom is electric and the two motors got out of synch so the two tracks were fighting each other. Causing the slide to bind after moving partially in. We were able to re-synch the motors and retract our slide and get on our way.
โJul-08-2018 11:18 PM
โJul-08-2018 05:58 PM
TxGearhead wrote:
Does it have rollers or a wear bar? If wear bar, spray the exterior bottom of the slide with WD40 Specialist with PTFE Doesn't Attract Dirt or Dust.
โJul-08-2018 05:53 PM
โJul-08-2018 05:51 PM
