best rv tires
telicodickie
Looking for suggestions on quality tires for my 32 ft fifth wheel. I have tried several imports and haven't been real pleased with them. ST2.35/80R16 is what I am currently using.
30 REPLIES 30
WeBeFulltimers
steelpony5555 wrote:
True, 6000 lb axles most any LT E rated tire will work, 7000 lb axles you'll need Goodyear G614 tires....
The actual scaled weight on your axles is what really counts. Even if your fiver has been upgraded to 8k axles the LT E tires will be fine if your total axle weight does not exceed 12,168 lbs (excludes pin weight). Or if you have accumulated excess tire money you can waste some of it on 614s.
2012 Ford F-350 PSD SRW ** CURT Q24 ** 2018.5 MONTANA 3791RD
JIMNLIN
Your ST235/80-16 E has 3500 lbs of capacity and come on 7k axles. If this is the case you will need to move up to a Goodyear G614 at 3750 lb capacity or the commercial grade Sailun S637 at 3750 lbs capacity. Both tires area LT235/85-16 G load range.
If your trailer has 6k axles or smaller the tires mentioned above work great.
mudmaker
I tried Yokohama. Found some last spring and replaced the tires on my 2010 Cougar. Liked them enough to insist they get put on the new Big Country I got last fall. Anything but trailer tires. Well maybe Maxxis.
Have had both Duravis 250 and the Transforce on my trucks and not had any complaints at all.
Glen and Loretta
Marc, Jake, Kirsten and fur kids Dexter and Bernie
2017 KZ Venom 4114TK Toy Hauler
2015 GMC Acadia
15 Silverado 3500 SRW quad 6.6 Duramax
11 Silverado 3500 SRW quad 6.6 Duramax
Brandon327
Has anyone tried the kenda tires?
2013 gmc 3500 hd cc Drw 4x4
2016 Dutchmen voltage 3990
Allworth
For 6K axles I have had excellent service from B.F. Goodrich Commercial TAs (LT LRE).
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
iawoody2
With a 5er your size the BFG Commercial TA would work just fine and they are reasonably priced. I have them on mine which weights 12100 loaded for travel and 9500 on the trailer axles. Pulled about 4000 miles so far.
Don___Carolyn
We recently put Bridgestone Duravis R250 on our Arctic Fox. They were recommended by a semi truck driver who also has a 5th wheel.
Don & Carolyn
2006 Dodge 2500 diesel 6 speed
17' Casita Independence Deluxe
Dave_H_M
I am running Firestone Transforce LT E with no probs.
Those or most of the above mentioned are good.
How to find out which is best would be a******shoot.
MrVan
We put Bridgestone R250 Duravais on our 2006 Montana 3400RL
Has 6000lb axles. Have about 5000 miles on them so far. All looks good after going through two sets of ST tires eith many failures.
steelpony5555
14 Cedar Creek Silverback 29IK
10 Dodge 3500 Dually Laramie 6.7 Diesel
14 Chrysler 300
07 Pearl White Ultra Classic (My new Baby)
Texas Boomers---Stop by for a Margie some time!
45Ricochet
roman traveler wrote:
I just switched out my XPS ribs (age, not wear) for Bridgestone Duravis 250s. Dealer I have been going to for over 50 years handles both brands, recommended the Duravis. Not because they are better than the ribs, but because they are basically the same tire at about $50 per less money.
RT
X2
This is assuming OP has 6k axles, not 7k lb axles of course
All these mentioned so far have roughly 3042 lb weight ratings.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
roman_traveler
RT
Dennis_M_M
X3 for Michelin XPS Ribs.
I had BFG Commercials prior to the XPS Ribs and they stood up well for 7 years on a heavy fiver. I replaced them simply due to age.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
the_bear_II
Michelin XPS RIBS
I researched for over a year by going through RV/Truck forums and consumer reviews. Time and Time again the Michelin XPS RIBS were shown as top rated. Most of the testimonials indicated the folks were getting way more life out of the XPS RIBS than expected. Many were in the expected 65,000 miles but got 90,000 miles range.
I've had the tires on my 5th wheel for 2 years with no problems.
Two_Hands
Michelins. Great on the fifth wheel we had and great on our coach.
2015 Fleetwood Excursion 33D
2016 Grand Cherokee Limited
Retired Law Enforcement
U.S. Army 1965-1973/RVN 1968-'69
I am the frequent recipient of "Get out of the way old man!"
