Apr-29-2017 11:47 AM
Apr-29-2017 02:56 PM
Apr-29-2017 02:22 PM
Apr-29-2017 02:06 PM
davisenvy wrote:
The leaf springs are already under the axles. Leaf springs have already been dropped to the lowest position and every adjustment has been made to try and level the FW. I am at the point where I need to buy new parts to help raise the back end of the FW to level it out. I currently have 6 in between the top of the bed rails and under side of the nose cone.
Apr-29-2017 01:54 PM
Apr-29-2017 01:28 PM
davisenvy wrote:
I just purchased a 2016 Ram 2500 and pull a 2016 Jayco Eagle HT 29.5bhds. The Jayco seems to be a little low to begin with, but with this new Ram I am towing way high in the front. I'm about 8 in nose high. I have read about people putting 4 in subframes under their FW, but I'm a little weary of this because of warranty reasons. The only other options I see is to get new wheels/tires and a Lippert Correct Track system that says it'll lift 2 in. This gets me closer, but it still won't be level. Any other lifting suggestions? Is a subframe the only way to go?
I called the dealer where I purchased the FW and the owner said that nose high conditions don't really matter anymore because of the CRE3000 suspension that's on it. I don't really believe that to be true, but what do I know.
Apr-29-2017 01:21 PM
rjxj wrote:
Are the axles on top of the spring or under the spring? If on top, you can do an axle "flip" and gain 4.5 or so inch.
Apr-29-2017 01:08 PM
Apr-29-2017 12:27 PM
Apr-29-2017 12:23 PM
Apr-29-2017 11:57 AM
Apr-29-2017 11:54 AM
Apr-29-2017 11:52 AM
