Big Country 3070RE vs Silverback 29IK
JCGibson
Hello Forum,
We have recently sold our toyhauler and are looking to get back into a traditional FW. We have narrowed it down to the Big Country 3070RE and Silverback 29IK. We would like to hear from respective owners with pros/likes and cons/dislikes about these models. Thanks!
John & Cheryl
John (USAF Retired) Cheryl (Mid School Teacher)
'16 Newmar Ventana 3709 Sold
'16 Tiffin Allegro 36LA traded
'11 Dodge 3500 Crewcab sold
'14 EverGreen Bayhill 295RL sold
'12 Voltage V3200 sold
'09 BigHorn 3400 sold
'06 Jayco Octane sold
'04 Jayco Baja sold
19 REPLIES 19
SooperDaddy
Big County is a Heartland RV which has moved to being the 4th best selling 5er company even tho Heartland has only been around for 4 years! When they started, several guys from other RV companies canme over to Heartland and hit the ground running. Innovative floor plans and unique building technics made customers sit up and buy! And customer service was supurb! Thor owns Heartland...and usually screws up the companies they buy...but Heartland was allowed to run as a competely seperate division and is one of the best.
The Silverback is Forest River product, the 2nd largest RV manufacturer and owned by Billionare Warren Buffet. The tremendous buying power of Buffet means that quality is not cut back and name brand equipment is used, and shortcuts are not taken. Buffet even has his Forest River Managers meet once week in his factorys and pull an RV off the line..and do a random quality audit on it. Every inch!
You've got a good eye for great RV's...and I'm biased towards Jayco!
Both companies FR and Heartland build high quality, well equipped and well made RV's with a LOT for your money. :B
So it would boil down to interior decor you like, floor plans and amenities that you like best!
For example the FR Silver back has as standards...
โ€ขLED Lighting w/ Lifetime Warranty *****
โ€ข10 Gallon Water Heater
โ€ข12 Volt Heating Pads on all Holding Tanks
โ€ขRoof and Underbelly - R38
โ€ขSidewalls - R9
โ€ข30" x 48" Rectangular Shower w/Glass Doors
โ€ขDucted 15,000 BTU Air Conditioner
โ€ขAttic Vents
โ€ขBrace and Wire for Second Air Conditioner
โ€ขDigital Thermostat for Heat and Air Conditioner
โ€ขBraced for Optional "Level-Up" Six-Point Hydraulic Level System
โ€ขBathroom Breeze Fantastic Fan
โ€ขCreate-A-Breeze Fantastic Fan w/Rain Sensor in Kitchen
โ€ขCathedral Slide Rooms
โ€ขCongoleumยฎ Diamondflorโ„ข
โ€ขDocking Station w/Easy Access Bypass Valves
for the Water Heater Systems
โ€ขEnclosed and Insulated Underbelly w/Heating Pads on ALL Tanks
โ€ขDexter E-Z Flex Rubber Equalization System
w/Greased Zerks and Bronze Bushings
โ€ขDexter Nev-R-Adjust Brakes
โ€ขDexter E-Z Lube Hubs
โ€ข16" Tires and Aluminum Rims
โ€ขFront Storage for Spare Tire
โ€ขLED Tail Lights and Lower Front Lights
โ€ขLighted Entry Step
โ€ข55 Amp Converter w/Charger
โ€ข50 Amp Power Cord
โ€ขRadius Ceiling
โ€ขNew Interior - Hickory Glazed Maple Hardwood
โ€ขSolid Wood Fascia - No Wrapped Foam - Try the "Tap Test"
โ€ขSertaยฎ Residential Dreamscape Mattress
โ€ขPorcelain Toilet w/Top Swirl Flush
โ€ขShawยฎ Carpeting
โ€ข"Soft Top" Vinyl Storm Doors Silverback Explorer Package (Mandatory Options)
โ€ขLED, Flat Panel, HD Ready Television in Living Room and Bedroom
โ€ข12 Volt CD/DVD, AM/FM Stereo
โ€ขTwo (2) Exterior Waterproof Patio Speakers
โ€ข8 Cu. Ft., Wood Front Refrigerator
โ€ขHide-a-Bed Sofa
โ€ข30" Over the Range Microwave w/ Vent
โ€ขLG Hi-MACS Classic Solid Surface Countertops
โ€ขTrue Nobel Classic "Pearl" Gel Coat Exterior
โ€ขBlack Tank Flush
โ€ขBathroom Breeze Power Fan
โ€ขRear Stabilizer Jacks
โ€ขFront Hydraulic Jacks
โ€ขEntire Water Filtration System
โ€ขCedar Creek Switch Control Center
โ€ขWinegard HD Roof Satellite Prep
______________________________________________________________________
HEARTLAND-
WIRELESS REMOTE CONTROL SYSTEM
Secondary wireless control system on key fob
Controls slide rooms, electric awning,
front and rear jacks, and outside lights
HAND CRAFTED BORDEAUX CABINETRY
All Cabinet Frames are Pre-Drilled and screwed together - not stapled
Euro style spring loaded on each cabinet door Hidden Hinges
Deluxe Ball-Bearing Drawer Guides
UNIVERSAL DOCKING CENTER
12V light
Tank drain pull controls with enclosed gate valves
Hot / Cold Exterior shower sprayer
Black Tank Flush
Water hook up โ€“ city and tank fill *ALL IN ONE*
RG-6 coaxial cable hook up
Dual Satellite Hook Up (Roof OR Tri-Pod)
Winterization valves and water heater bypass
BIGGEST EXTERIOR STORAGE In Class: Over 145 Cubic Feet of Storage!
Large Insulated Slam Style Access Doors on compartments
Unobstructed Pass-Through Design
110V Outlet &Cable TV Plug
12V Trunk Lights
BEDROOM
Large Walk-In Front Wardrobe
Two Windows in Slide for Better Air Flow
Over 6โ€™-4โ€ full profile Bedroom Ceiling Height Throughout
Reading Lights Over Bed
Speakers in Bedroom
EXTERIOR FEATURES
Exterior Speakers
12V Sound System
2 Molded Security Lights
Light at Entry Step
LAMINATED FLOOR CONSTRUCTION
Strong Aluminum Framing
Block Foam Insulation
3/8โ€ Seamless Decking (No squeaks)
Thermo-Board Luan on the Bottom
LAMINATED ROOF CONSTRUCTION
5โ€ Laminated - Block Foam with Aluminum framing
Fully walk able Roof
One-Piece Seamless roof protection
LAMINATED WALL CONSTRUCTION
High gloss gelcoated exterior walls
2โ€ thick, 6 layered sidewall
Double-Welded Aircraft Quality Aluminum throughout
FRAME & LANDING GEAR
Strong 12โ€ I-Beam Frame
w/Drop Frame (most models)
Hydraulic Front Jacks
Heavy Duty Rear Stabilizer Jacks
TIRE/AXLES/SUSPENSION
Correct Track alignment
Heavy-Duty E-Rated 16โ€ Radial Tires
Dexter EZ Flex Suspension with shocks
Aluminum rims
7,000 lb. Axles
2ยผโ€ x 12โ€ Nev-R-Adjust Brakes on each hub
ABS Fender Skirts
UNDERBELLY
Seamless Corrugated Underbelly Material
Heated, enclosed, and insulated underbelly, holding tanks and gate valves
PLUMBING
Color-Coded Plumb-PLEXโ„ข Water Lines
75 Gallon Fresh Water system
90 Gallon Gray and 45 Gallon black tanks
(2) 30# LP bottles
POWER
80 AMP/12V DC Power Converter with charge wizard
50 Amp Detachable Marine Cord
110V Exterior Electrical Receptacles
HEATING
40,000 BTU Furnace
Heated Stool Room
COOLING
15,000 BTU ducted Air Conditioner
Air Conditioned Stool Room
Wired and Prepped for 2nd A/C
INSULATION VALUES
Walls โ€“ R11 Insulation (calculated)
Roof โ€“ R38 Insulation (calculated)
Floor - R38 Insulation (calculated)
Slide Rooms Floor - R38 Insulation
MAIN SLIDE ROOMS
7โ€™2โ€ Slide Room Ceiling Height
Cabinets Above Sofa
Hydraulic Operating System with manual override
Triple Sealed
w/One-Piece Weather-proof Floor Pan
LIVING ROOM
Decorative Glass Inserts in Overheads
110V Ceiling Fan
with Light Kit (most models)
Hard Valances
FOR YOUR PROTECTION & SAFETY
Smoke Detectors on Ceiling
Fire Extinguisher by Entry Door
LP Gas & CO2 Detectors inside Unit
Exterior Security Flood Lights
Break Away cable Switch
Deadbolt Lock on Entrance Door
120V GFI Protected Outlets
Fire Escape Windows
All Safety Glass Windows
12V Hitch Light
KITCHEN
Stainless steel appliances, sink, and hardware
Room for Large Trash Can
Residential Sized Cabinets with euro
style hidden hinges
Residential Size under mounted Stainless Steel Sink
Deep Residential Size Drawers
Large, Deep Pantry w/Adjustable Shelves plus pull out pantries
Standard Fantastic Vent with Wall Mounted Thermostat and Rain Sensor
BATH AREA
6โ€™-4โ€ Bath/Bed Ceiling Height Throughout
Large Medicine Cabinet
Vanity Light Bar and Wall Mirrors
Vessel sink with added countertop
SHOWER
One-Piece Fiberglass Shower
Mega-Bath (select models) with Glass Shower Surround
Adjustable Shower Head
Skylight over Shower
COMMODE ROOM
Power Roof Ventilation
Porcelain Commode w/Foot Flush
Storage Shelf
110V Outlet
And Heartland-Unusual for a RV Manufacturer...will do custom stuff during construction.
Good luck!
My posts shouldn't be taken for factual data, and are purely fictional, for entertainment purposes, should not be constituted as related to scientific, technical, engineering, legal, religious, spiritual, or practical advice. After all it's FREE! Amen. :W
B_O__Plenty
Heartland products have a great owners club and forum plus nobody has better customer service than Heartland. Very easy to contact anyone in the company including, Brand Managers, Parts managers and and on up the line. Nothing wrong with the Cedar Creek products but I think Heartland is a cut above..Besides that 3070 model with the high ceilings is MIGHTY NICE!
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
kakampers
Big Country is a Heartland product...
2013 Heartland Landmark Key Largo with Mor Ryde IS and disc brakes
2011 Chevy Silverado 3500 DRW Crew Cab Duramax Diesel
OpenRangePullen
Go with the Big County!!!
2013 OpenRange Roamer 395bhs
2022 F350srw Limited, tower
2021 F150 Platinum Hybrid, daily
2002 Accord V6/5spd, project
2014 Kawasaki Concours
donn0128
Big Country is a Keystone/Thor product right? Cedar Creek Silverback is a Forest River product. After 8 years of ownership (11/04 build date) my cedar creek has been perfect. I currently have two issues that need taken care of. Both I really consider normal wear and tear issues. Both I have parts for when the weather warms. Both parts I got from CC after one phone call. They are easy to deal with and still have parts for my 2005 fiver. Today it is 29 degrees outside with a light east wind. We are sitting full time with our back window facing east and the river. We have a oil heater and with that we can maintain around 67 degrees inside with occasional use of the furnace. Not perfect but insulation value of the Cedar Creek is pretty decent considering age and conditions. The difference between a regular CC and the Silverback is mostly fluff. Options on the SB are standard on the CC. In reality if you load up a Silveback you can buy a CC loaded with the same features plus more for nearly the same price.
