Aug-03-2016 08:04 PM
Aug-04-2016 09:24 AM
Aug-04-2016 09:13 AM
Aug-04-2016 08:53 AM
Larryzv7 wrote:Yea don't do that.
.....I have done a lot of mountain camping or gone over lots of mountain passes where I ride my brakes.....
Aug-04-2016 07:35 AM
Aug-04-2016 07:23 AM
Aug-04-2016 05:59 AM
DownTheAvenue wrote:X2
www.powerstop.com
Aug-04-2016 05:47 AM
Aug-04-2016 05:41 AM
thomas201 wrote:
Get any good quality brake pads, the OEM are good on Fords. If you do not feel pulsation, the rotors are fine. Take them off and check run out if you are technical.
Aug-04-2016 05:01 AM
Aug-04-2016 04:26 AM
Aug-04-2016 01:48 AM
Aug-04-2016 12:18 AM
Aug-03-2016 10:55 PM
B.O. Plenty wrote:
Looks like a big load for an F-150. Have you weighed the trailer and matched the weight against the towing capacity of the truck? Trailer brakes don't do nearly as much as you would think they do.
B.O.
Larryzv7 wrote:
Everyone who sees my F-150 towing a 5th wheel says “it looks like a small truck to be towing a 5th wheel.” I have had this discussion many times; yes I have weighed my trailer and truck and I am at least 1,000 lbs. below my trucks towing capacity. The rear wheel ratio and echo-boost engine makes all the difference in the world, and I have been towing my 5th wheel for almost 5-years with this truck. I can go over mountain passes at 70mph without any strain whatsoever and most of the time it does not even feel like I am towing anything. I get between 9 to 11 mpg depending on how fast I drive. I like my rig combination very much and it really sets those with an F-250 or above back on their heels. Although I think I may benefit from some heavy duty brake pads.
P.S. My F-150 is an automatic and I usually use over-drive when towing. BTW, As a retired person I go out with my RV 2-weeks each month so I do a lot of towing, and I lived in my 5th wheel for 2-years, renting out my house, when I first got it.
Aug-03-2016 10:03 PM
azdryheat wrote:
If your trailer's brakes are operating properly there wouldn't be any overheating of the truck brakes. I'd be checking the trailer.
Aug-03-2016 09:29 PM
