> Mountaineer Montana 298RLS by Keystone with a 91,000 to 91,300 w/carrying capacity of 3150
I think you have the comma in the wrong place, 9,100-9,130lb (empty/dry)
plus (food, chairs, clothes, water in tanks ...) stuff (carrying capacity) of 3150 lbs.
so total trailer weight (GVWR) = 9100+3150 = 12,250. (there should be a label on the trailer with its GVWR, usually front drivers side somewhere)
for a 5th wheel, the hitch should have 15-25% of the total trailer weight. so 9100*.15 to 12500*.25 is the same as 1365 to 3125 lbs.
(higher is generally better).
this hitch weight will be in the bed of the pickup truck, so the truck has to be able to 'haul' that much (vs PULL the rest).
the truck 'haul' capacity includes ITs fuel, passenger weight, and whatever else ends up in the truck or bed (some carry firewood in the bed, this counts as truck haul weight)
its all a balancing act.
the truck is rated by 4 values.
1. total maximum weight (gross vehicle rating, GVWR)
2. maximum weight on front axle (FAWR)
3. maximum weight on rear axle (RAWR)
4. maximum combined weight of truck and towed thing. (gross combined vehicle weight rating) (GCVWR)
the 1st three are usually on a sticker on the drivers door post.
the latter will be in some document from Ford.
2002 towing guide see page 19,
says GCVWR is 20,000 for 250 with 7.3
so that means your truck (fuel, passengers, stuff, hitch weight)+trailer (and stuff), should not be more than 20,000 total.
(while keeping the other 3 numbers in line too)
a weigh scale ($8-$10 charge) will tell you exactly what the truck weighs before adding all the stuff. the tags only tell you the MAX, not actuals.
here is a good
worksheet to help do the math.
now, SOME have been willing to go over these numbers, assuming that Ford (chevy/dodge) has designed in some spare capacity. Many do this everyday without problems. Some have disastrous results.
I traded in my 250 (10,000 GVWR and 6100 RAWR) for a 350 dually (13300 GVWR, and 9000 RAWR). The dually with the trailer connected weighs in a 11,900 (5240 FAW, 6660 RAW). so 1,900 more than my 250 allowed and 560 over the RAWR, trailer not yet loaded up.
2012 Ford F350 DRW, 6.7 diesel.
2013 Keystone Alpine 3720FB
