We have a 2013 Forest River Wildcat Rear Living 5th wheel. Cable TV has never worked great but has been much worse the last 4-5 years, If I run Cable from Campground post direct through window to any TV reception is perfect. Through the main 5er cable input it is very snowy. I replaced the Antenna power boost outlet and removed all 4 of the Cable hookups and verified a tight connection. I also checked the main Cable input to verify tight. No change in snow. None of these have a splitter connected to the cable. I pulled all lines out as far as they had slack and no splitter. I then removed every access panel in the main trailer and basement to look for a main cable splitter. NO luck. There has to be one somewhere as this trailer has 1 cable inlet and 4 cable outlets. Does anyone have any idea where it could be? I will contact Forest River but my understanding from research is that RV's are wired based on the whim of the crew that given day. Thus I expect no real help there. We can use antenna reception but DW prefers the cable variety. Hoping to get help narrowing down the hunt.
Greg
You cannot stop growing old but you don't have to grow up. 🙂
Chef/Pilot
DW/Navigator
2 Sons, 1 DIL, 3 Grandsons, 1 Granddaughter. Boz the cat:)
2012 F350 XLT 6.7 Powerstroke 4X4 SWD Crewcab.
2012 Wildcat 313RE-OK
