Can't locate CO detector
mirving524
I have a Forest River XLR Hyperlite 2013 and can't locate the CO detector. Maybe it doesn't have one? Anyone know?
9 REPLIES 9
Yeti_plus
In our trailer the CO and Smoke are separate units, in the truck camper there is a combination CO/smoke detector.
Check your smoke detector to see if it is combination unit.
You may have to take it down to read the label on the back.
2014 Chevrolet 3500 CC 4X4 Duramax, Tork Lift Tiedowns, TorkLift Fastguns, Superhitch and supertruss
2009 Jayco 213 SOLD
2008 Bigfoot 25C9.4
Me_Again
ScottG wrote:
A CO detector can be mounted at any level as it mixes easily with air and that's why they combine them with PP detectors. That's also why the plug in types are so common for residential use.
CO is only ever so slightly lighter than air - not enough to matter.
Example
Propane is heavier than air and a detector is normally mounted low. Ours is on the slide side wall behind the dining table chair, less than a foot above the floor. Chris
john_bet
Example
In my '05 Montana and my current 2018 Grand Design it was/is mounted in the bed room high up on the wall.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
ScottG
Example
BB_TX
If you have propane devices (stove, furnace) it should have a CO monitor somewhere. My 2007 Montana has CO detector in the bedroom. And smoke detector and propane detector in the living room. CO detector mounted high up on wall. Smoke detector mounted to ceiling. Propane detector located near floor.
And it is not gen preped.
ScottG
It's probably combined with the Propane detector - mine is.
BTW, ALL rv's built after a certain year were equipped with one from the factory.
MFL
Nomad II
Nomad II
4x4ord wrote:
You could always run a hose from your tailpipe into the trailer. If there is one there it wouldn't take long to locate it.
:B Yes, this will find it! Often times the propane and CO are combined. I would think most any 2013 model would be so equipped. Maybe a call to manufacturer will get the answer, if you don't have a tailpipe hose.
Jerry
Chris_Bryant
It will only have one if it was factory equipped for a genset- IOW, rigs with internal combustion engines are required to have CO detectors, those without don't.
-- Chris Bryant
4x4ord
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
