Ceder creek champagne
Xflyhighx
does a 2019 ceder creek 38EL have disc brakes
โš Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" at the top?
    Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post your topic in the RV Forum which corresponds to the subject of your topic. Thank-you!
2019 Cedar Creek Champagne 38EL
TrailAir Pin Box
Hensley TS3 trailer saver
2017 Laramie Longhorn 4x4 dually
14' Porta-bote
Honda 3000is or 2 Honda 2000โ€™s
Life is good in the good old USA
7 REPLIES 7
Xflyhighx
Thanks again
TrailAir Pin Box
14' Porta-bote
pcm1959
Only FR fiver with is the River Stone line.
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
1492
Moderator
Moderator
Moved from Forum Posting Help and Support
From the Forest River site -
SUPERIOR PERFORMANCE
Dexterยฎ Axles/Brakes Suspension For Performance and Safety
Nev-R-Adjustยฎ Brakes are always properly adjusted for improved stopping power in half the distance
E-Z Flexยฎ rubber equalization system with 1/2โ€ link plates and eight grease zerks per side
Heavy duty axles with bronze bushings in shackles (No plastic bushings like our competitors)
17.5โ€ 8 Lug, ST โ€œHโ€ rated tires on 8000 lb. Dexterยฎ Axles
STANDARD FEATURES
Nev-R-Adjustยฎ brakes
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
pulsar
I believe it uses the Dexter Nev-R-Adjust drum brakes.
Tom
2015 Meridian 36M
2006 CR-V toad
3 golden retrievers (Breeze, Jinks, Razz)
1 border collie (Boogie)
Xflyhighx
Thanks a lot
TrailAir Pin Box
14' Porta-bote
donn0128
Likely not.
