Changed the rear springs
Road_Phantom
(My 2018 diesel Ram 4x4 2500 has coil springs front and back. I'm overloaded on my 5th wheel (2000lb hitch weight) and total GVWR by 800 lbs after everything is loaded up for travel.
My local spring guy claims a heavier duty coil spring upgrade would solve the overload problem, since everything else on the 2500 is heavy duty. I would like to know if anyone else did the same to their similar truck and recommend it. Thanks.)
That was my last post. Today, I got my truck back from the local spring shop with new heavier duty rear springs. They ride great, if not better than the worn in originals. The next thing is to test the load from the fiver, but have to wait for some snow and ice to melt in the storage lot. Hopefully, the lights in the faces of oncoming traffic will be fixed. If not, then I'll have to install a pair of airbags.
21 REPLIES 21
Cummins12V98
StirCrazy wrote:
Cummins12V98 wrote:
" If not, then I'll have to install a pair of airbags."
IMHO bags should have been the first choice.
bags are a bandaid, springs are probably the best choice but also the most expensive. having had bags before I would buy timberans before I waisted money on bags again.
Steve
Not really. Two whimpy full length springs to hold things together and then the air bags do all the work. 9,750# on the rear tires. Nice ride loaded or not.
YES this ia Factory Rear Air Ride but the same applies with standard springs.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
StirCrazy
Navigator
Navigator
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
pianotuna
Nomad II
Nomad II
Hi,
I replaced my broken air bags with Timbrins. The air bag cradle broke the welds to the frame.
Regards, Don
MFL
Nomad II
Nomad II
Agree...if you needed anything at all, bags should have been first consideration.
Jerry
Cummins12V98
rhagfo
Well you are still overloaded, by GVWR, and wondering just how close you are to tire and axle ratings. Don’t know what 5er you have but if you are at 10,800# GVWR unless you carry a ton of stuff in the bed your pin is closer to 2,500#. Otherwise math says your truck less pin weighs 8,800#,’which is 200# more than my 2016 Ram 3500 DRW base weight.
pianotuna
Nomad II
Nomad II
Thanks for the update.
How deep did you have to dig into your pockets?
Regards, Don
