โMay-12-2015 08:23 PM
โMay-15-2015 08:49 PM
Baja Man wrote:
Can't I just use remove the wires from the old plug and place them into a new 7 blade plug? In the pics posted, the wires are set into terminals with set screws. Am I correct?
โMay-15-2015 08:01 PM
โMay-15-2015 06:56 PM
โMay-13-2015 08:53 PM
smkettner wrote:
I would put a new plug on with the flat blade connectors.
No adapters unless you are just towing it someplace to sell.
โMay-13-2015 06:50 PM
โMay-13-2015 06:46 PM
Baja Man wrote:
Thanks for the replies.
What are the thoughts on using an adapter that goes from 7 pin round to 7 pin flat? Like this one....
7 round to 7 flat adapter
โMay-13-2015 05:53 PM
RustyJC wrote:My bad I thought the trailer had the flat and truck round. I never owned a trailer that did not have the flat blade's.
The OP wants to change the trailer to the NEW style industry-standard Pollak 7-pin flat, which I'd highly recommend in case he ever needs anyone else to be able to tow the trailer.
I'd be careful and chase each wire since the 1996 and 2000 Jayco Designer 5th wheels I owned came with the Pollak 7-pin flat. If the Jayco you're looking at has a 7-pin round, that's non-standard for the Jayco and there's no telling how the previous owner had his truck wired.
Here's Pollak's standard for a 7-pin round:
Here's Pollak's standard for a 7-pin flat:
Rusty
โMay-13-2015 05:08 PM
โMay-13-2015 04:41 PM
โMay-13-2015 04:08 PM
Old-Biscuit wrote:
Take pics of old wire connections BEFORE disconnecting wires........:B
โMay-13-2015 05:58 AM
โMay-13-2015 05:35 AM
โMay-13-2015 03:23 AM
โMay-12-2015 09:56 PM
