Jun-17-2023 04:23 AM
Jun-19-2023 05:51 AM
Jun-18-2023 08:50 PM
fj12ryder wrote:
If you're hooked up to shore power all the time, go to Wally World with the measurements of your battery box and buy a deep cycle battery that will fit. Not a starter/deep cycle battery. A deep cycle marine battery will work fine, and probably run you under $100. If that battery you have is the original, I think you got all the good out of it. 🙂
Jun-18-2023 05:38 PM
Jun-18-2023 01:24 PM
Jun-18-2023 10:58 AM
joelc wrote:Any battery is fine if connected to utility power. The PD converter will never let it get low on voltage. Actually a battery is not even needed unless the RV moves. AGM is fine for reduced maintenance. Don't need high capacity unless unplugged overnight.
Also, I live full time, and am hooked up to shore power.
Jun-18-2023 06:33 AM
Jun-18-2023 05:00 AM
Jun-17-2023 05:46 PM
Jun-17-2023 10:06 AM
joelc wrote:OK if the PD is producing 13.2 to 14.4 volts there should be same voltage at the stack of 12v fuses in the panel.
Checked the Charger/Converter per Progressive Dynamics directions, and it is fine.
Jun-17-2023 08:47 AM
Jun-17-2023 08:39 AM
Jun-17-2023 08:30 AM
Jun-17-2023 07:57 AM
Jun-17-2023 07:21 AM
joelc wrote:
Agwill The fridge is a 12 Volt only. Dometic DMC 4101
To enlarge on my question with some more information. I currently have a Gel battery and according to the battery condition light in my RV it is in the RED zone. I can't run the fridge and lights without the lights dimming. So, the battery being less than 1 yr. old is not holding voltage.
Jun-17-2023 07:06 AM
