cold temps and water heater?
freewayrandy
How cold and for how long before you think about draining your water heater? Been having temps in low 20's from sundown to sun up and getting concerned.
2022 Chevy Silverado 2500 HD Duramax/Allison, 2024 Cougar 27SGS
13 REPLIES 13
I drain my water heater IF I am not going to use the RV in the next 2 - 3 weeks....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
2oldman
I'd just keep the WH on. Also a 55F furnace setting. Pipes are at a much greater risk than a water heater.
Lwiddis
IMO a water heater that is not being used should be drained regardless of temperature.
way2roll
Navigator
Navigator
If you have been having sustained temps in the low 20's F, then it may already be too late. It takes one gallon of water 4 hours to freeze at 32 degrees and expands 9%. Have you already drained the rest of the system? Pipes, pumps, strainers, unions and fixtures will crack first.
If your plan is to fire it up, I would wait around a while to look for leaks. You may end up thawing it, revealing a leak and subsequently heating air if left alone.
Jeff - 2023 FR Sunseeker 2400B MBS
pianotuna
Nomad II
Nomad II
freewayrandy wrote:
Not using it now but will end of next month. Forcast shows lows coming up to around 35 in the next few days. May just turn it on for a few days.
Drain
Blow the lines
install antifreeze
Hope that there has not already been damage.
Regards, Don
freewayrandy
2oldman
are you using it?
pianotuna
Nomad II
Nomad II
-5 c = 23 f.
Regards, Don
joebedford
Nomad II
Nomad II
-5C
time2roll
dougrainer
My answer to customers has always been----If it is below 32 degrees, take precautions and drain. There is NO WAY anybody can give a definite answer to your question about how low and how long freezing temps before damage happens. IF you have the Water Heater in use(LP or 120), then I would not worry. That is 140 degree water. But, as I also tell customers, if in storage, what happens if the Power goes out or your LP system malfunctions. Doug
wildtoad
If youโ€™re not using your wh drain it. Perhaps your manual says just that.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
CarnationSailor
Any predicted temp at or below 35 and I drain it unless, of course, I am using it.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
