Curt fifth Wheel Hitches
rkassl
Going from a short bed with a Pullrite Super Glide to a long bed where we don't require a slide hitch. Does anyone have any comments regarding the Curt Hitch, good , bad or otherwise? Any first hadn experience will be appreciated.
Thanks!
2015 Montana 3440RL Legacy Edition
PullRite Super 5th 20K hitch
Morryde Pin Box
Dish Tailgater and King Tailgater Satellite Systems
2016 GMC Sierra Denali 3500 SRW CC full bed
116 REPLIES 116
Ohiojude
We have a Q20 Curt and LOVE it! We had a Reese 16k with our last 5vr. Comparing both this one is quieter and seems to be a smoother ride.
2015 Chevy 3500 LTZ diesel dually, Curt Q20 Hitch
**traded in-the lemon- 2012 Winnie Raven 5th Wheel**
for a marvelous-2014 Big Country 3596RE
Traveling with 3 wonderful Feline Furboys Milo, Mason and Mozart
jerem0621
Those jaws are more than sufficient on the Curt...on the E16 of the slide bar was coming out then the hitch was defective...handle down = Locked....And it's a $275 ish hitch...you do not get top quality hitches for that money.
The Q20 in the picture above is a BIG heavy hitch. That center section is a block of solid steel...not bolted together sheet metal. The jaws are more than sufficient and the lockout mechanism is secure.
Not trashing the B&W it's a fine hitch too...
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
Cummins12V98
Goostoff wrote:
Here is a side by side comparison of the 20k lb curt and the 16k lb B&W Decide for yourself what looks like better quality.
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
How about compare the 20K Curt with the 20K B&W or the B&W RVK3600 to the equivalent Curt.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
Goostoff wrote:
I just love seeing all the replies when this comes up. There are so many people out there that say they loved their Curt hitch...."But we upgraded" LMAO
I had a Curt Q16 and I upgraded to the B&W Patriot. I went with the Patriot because I didnt have to change the rails to make the upgrade.
The Curt Q16 was the biggest POS I have ever seen. There was no provision to latch the slide bar and every time I would get to the campground the bar would be slid out and wedged at an angle. It got to the point where i was putting a ratchet strap on the handle to secure the hitch. Any company that would come up with a dangerous system like that will never see another dime of my money no matter how "good" the rest of their products are.
There seems to be a lot of negative comments along with how after they fixed or figured it out it worked fine comments on here about the Curt hitches.
A hitch should be simple to use without any indicators or fancy anything. It should be solid and simple to use no matter the brand.
Stefonius
I love my Curt Q20. It's quiet, reliable, easy to hitch and unhitch, and you know instantly when you're properly hooked up. The hitch is solid and heavy and I've never had any troubles with it.
2003 F450 Crew Cab, 7.3 PSD "Truckasaurus"
2010 Coachmen North Ridge 322RLT fiver "Habitat for Insanity"
I love my tent, but the DW said, "RV or Divorce"...
Me_Again
Grey one is USA made!
Black one is china made!
Mine is grey, could have got a black one at a wholesale price but passed that up.
Look at the size difference on the jaws!
Black = thin
Grey = thick
Study how the jaws are locked closed. Grey has a dual end cam piece that blocks the jaws from opening.
Chris
azjeffh
Comparing apples to apples....The B&W RVK3300 weighs 153 lbs while the Curt Q20 (16035) weighs 164 lbs. Looks can be deceiving.
Jeff
Wonderful wife Robin
2016 F350 PSD Dually
2016 DRV 38RSSA
Goostoff
1993 Chevy C3500
2005 Cedar Creek 34RLTS
Goostoff
1993 Chevy C3500
pizzaguy
I had the Curt Q20 and it was a great hitch. I sold it to a friend when I upgraded the TrailerSaver TS3 air ride.
2017 Heartland Bighorn 3970RD
2017 Ford F350 DRW 4x4 Lariat
2013 Polaris Ranger
2 Silver Miniature Schnauzers
2012 Kubota Grand L3240
Louba
The only hitch I've owned is a Curt 20K and have been very happy with it. Not sure why anyone would recommend against it. It hitches, it unhitches, it's quiet...what else would you want? My guess would be that you probably wouldn't go wrong with just about any hitch.
2011 Bighorn 3385RL
2005 Chev 2500HD LS 4x4 D/A
Curt 20K
jerem0621
Cummins12V98 wrote:
"Reese make a 25k hitch to drop into the Ford fifth wheel prep kit.... Not sure why B&W won't rate their hitch accordingly"
Because B&W rates their hitches conservatively. Just look at the ridiculous 24K rating of the Andersen and then compare it to s B&W Companion that is rated at 20K.
Bottom line if you are in the market for a non air ride hitch there in none better than the B&W hitches. Just compare the simple solid design to any other hitch out there before buying.
If it matters a lot of REESE hitches are made in Mexico if not all and ALL of CURT 5th wheel hitches are now made in CHINA. PullRite as far as I know are made in USA as is the full line of B&W products.
Hitch in pic B&W RVK3600 25K towing and 6,250# pin.
Not disputing that at all..but the Reese 25k has the same rating and is a significant hitch as well... No reports of failures or major issues with the Reese 25k elite.
I share your sentiment about the Andersen....there is at least one report on an Amazon review where the Anndersen socket cracked. Now it's an Amazon review so TIFWIW....but the kingpin socket is where I would expect the failures to be with the Andersen...not so much the hitch itself but the kingpin adaptor.
Thanks!
Jeremiah
TT - Zinger 270BH
~Walt Disney~
avvidclif1
I went from a Husky Slider to a Curt Q5 20k. The Husky didn't care how you hit the pin it worked. The Curt is a little more picky until you figure it out. It doesn't like the "ride it up the ramp" or being much off level side to side. Once you figure that out it's a much quieter and smoother riding hitch than the Husky. I changed because I never used the slider and I put the TV on a diet.
Clif & Millie
2009 Ford F350 SRW CC Lariat 6.4 Diesel
2015 Heartland Cyclone HD CY3418 Toy Hauler
Cummins12V98
Learjet
I can say from experience, stay away from the Curt Q16...too many issues.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
