Cyclone Toy hauler pulled by a Ford F-250 crew cab.
deltamaster
Guy pulls in to the camp ground a couple days ago spewing fluid from underneath the pickup. Manages to get the rig in a site after leaving a trail all over the place.
He is pulling a Cyclone fifth wheel Toy hauler loaded with a small car that likely weighs around 2000 pounds. He also has a lot of patio gear such as full-size gas grill and furniture adding and he likely has another 1000-1500 pounds of stuff in the rig in gear and stuff including the patio gear. He also has the full patio kit for the rear lift gate.
Pulling it with a crew cab F-250 4X2 dually.
I checked some basic numbers and the rig itself weighs around 14400 pounds without the car and gear.
According to one guide I found the pickup is only capable of towing 12500 pounds.
I saw them pulling it up on a roll-on wrecker today and spoke with the guy. He said he blew the front main transmission seal.
Would you all think the pickup is overloaded hence why the front main seal on the automatic transmission gave up the ghost?
:E [purple]I ride it like I stole it![/purple] :B
.......and I just may have.......
I'm on "CB-13", are you?
2004 Fun Mover with a 1998 Road King and a 2002 Sportster tucked in the garage, Dragging a 2002 "RAM Tough" Dodge Dakota Crew Cab. Ohhh what a haul!
TSgt(Ret.) USAF
26 REPLIES 26
TXiceman
MTPockets1 wrote:
An F350 DRW with Deisel can tow 5th wheel 26,000 lbs, maybe more depending on year and rear axle ratio..
And were did this information come from. I cannot find an F350 near that except for maybe a 2015.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
deltamaster
MTPockets1 wrote:
An F350 DRW with Deisel can tow 5th wheel 26,000 lbs, maybe more depending on year and rear axle ratio.. If you're looking at conventional towing, using bumper pull ball hitch, then it's closer to 16,000 lbs.. He's OK for the Cyclone.
The data sheet I looked at did not note what you mention. Thank you for the information.
TSgt(Ret.) USAF
jimmyfred
..........If , most of that weight was loaded in the very back of the trailer , wouldn't that tend to lower his pin weight on the trailer ? , jf
2003 Chevy 8.1 Dually 2Wdr.
1999 Travel Supreme , 33 RLSS
20K Reese , Prodigy etc.
MTPockets1
2012 3055RL Big Horn - Dexter upgraded axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
deltamaster
Come to think of it, if the rig weighs in at 14400 pounds dry and you add the car at 1600 pounds then that in itself is 16000. Then you add at least another thousand pounds in gear, stuff, fluids, dishes, pots, pans, grill, etc and she is now at 17000... round it down to 17K and he is still 2000 pounds overweight for the truck which might have been what caused the tranny seal to go.
Sorry about the initial confusion
TSgt(Ret.) USAF
tegu69
One of my neighbors pulls his toy hauler with his f-150. I haven't seen him put a car in it, but he hauls his atvs. As far as the seal. Maybe it was just bad.
deltamaster
After he mentioned about dragging that huge rig around I remember telling the guy he might need a "450" and he told me "No way!"
TSgt(Ret.) USAF
deltamaster
CARP... Did I keep saying 250? I MEANT 350! My bad... OK... Weight rating is 15K pounds. With the rig dry weight at 144000 and the car and the gear he is still overweight. My bad. Wonder then why she blew the tranny seal!
TSgt(Ret.) USAF
deltamaster
Edited due to my inaccuracy.
TSgt(Ret.) USAF
Campinfan
An F250 dually? I am not a huge weight police type of person but I do agree there are limits and common sense. He seems to be violating both.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
mrkoje
I think your numbers may be wrong - were you looking at numbers for an F250? You mentioned he had a F250 dually. I could be wrong but I've never seen an F250 with dual wheels - kind of defeats the purpose of having DRW if it's only a 3/4 ton truck.
RAPTOR 300MP
RAM 3500 MEGA CTD 4X4
deltamaster
Oh, when I mentioned he might need a bigger truck after he said "I have to pull that big beast around" he said NO WAY! Big enough!
TSgt(Ret.) USAF
