โJun-01-2017 03:23 PM
โJun-05-2017 06:51 AM
Likes to tow wrote:
To all of you still using the EZ Lube feature on your axle be aware of the issues with this system!! If you have been pumping away with your grease gun and nothing comes out there is the possibility that the rear seal has blown out and your are lubing your brake shoes and magnet assemblies. I highly recommend you pull your brake drums and inspect for grease on the brakes~!!! There are significant amounts of opinions on using the easy lube system but most experienced Rv'ers will only hand pack the bearings. Easy Lube is wonderful for boat trailers that get submerged in water but useless on any trailer with brake actuators operating on the highway. Do a search on this and other forums about this issue and you will find an overwhelming number of people have had major issues with grease on their brakes. Look at the Grand Design owners forum and see the issue with Lippert and the massive replacement of complete brake assemblies due to grease getting past the seal.
โJun-05-2017 03:26 AM
โJun-04-2017 03:50 PM
Uh, you may have read some posts on the GD forum but clearly not all of them because you're missing THE most important fact.
The problems with leaking axle seals from the OEM have ZERO...I state again...ZERO relation to the EZlube system.
The EZlube zerks are not touched at the factory!
Do a test the day you opt to repack your bearings manually. Before you pull the hubs, try to force grease into the hub via EZlube zerk as fast and hard as you can. Try to blow that seal. You wont.
It takes significant pressure to blow out an axle seal with a grease gun. And if it leaks any grease, well then it would leak (or is leaking) under normal use and its good you are replacing it!
โJun-02-2017 06:49 AM
azdryheat wrote:
Frankly, I see no reason to fill up the hub with grease. Too easy to blow grease past the inner seal and contaminate the hub and brake linings. I too have the EZ lube axles but I don't pump in the grease. I grease the bearings, re-install them, and nothing more.
โJun-02-2017 06:38 AM
โJun-02-2017 05:55 AM
โJun-02-2017 04:37 AM
Colo Native wrote:MFL wrote:Colo Native wrote:
It will not go in with the hub in place but if I take it off it will flow through the hole, but it doesn't fill the cavity with the bearings in place
Are you using too thick, not recommended grease? Are you raising the wheel slightly, and turning it a little as you pump grease? I needed 50 strokes of the lever before grease started to move through the front bearing, when starting with an empty hub.
Even a hand operated gun, will push the grease out at some point, even if it has to move through the seal onto the brakes.
A couple tips, put the grease gun in the sun a bit, before use. The grease flows through warm bearings better than cold.
Jerry
Done all of the above. Using approved grease, 5 minutes of pumping and nothing took hub off and no grease, but it comes through the holes in the axle spindle
โJun-02-2017 03:09 AM
โJun-01-2017 09:22 PM
โJun-01-2017 08:28 PM
โJun-01-2017 06:46 PM
โJun-01-2017 06:40 PM
โJun-01-2017 06:35 PM
Jerry
โJun-01-2017 04:49 PM
