โMar-06-2017 12:37 PM
โMar-09-2017 06:26 AM
Likes to tow wrote:shepstone wrote:Cummins12V98 wrote:shepstone wrote:
I prefer to hand pack them myself , that way I get a good look at the brakes, bearings, races and all the other components. Plus it's just plain old too easy to blow out the seals pumping that much grease in there.
After actually pulling my hub off, inspecting, adjusting the bearings and pumping in the grease I have to say I completely disagree!
I felt virtually no resistance difference while pumping the handle when the cavity started to fill.
Do it whichever way you want too, it's your trailer, but on my trailers EZ lubes aren't a maintenance replacement for disassembling & inspection of bearings, races, spindles, brakes, magnets and other hub
components.
If that cavity is totally full of grease, what happens when the brakes heat up the drum/hub and the grease expands. Where does the grease go?
The picture shown appears to be from an axle without brakes! On an axle like this Easy Lube is the only way to go! Just pump till your hearts content and let the grease ooze onto the wheel rim. If you have brakes on a trailer then the cleanliness of those brake shoes and magnet is of upmost importance.
โMar-09-2017 04:38 AM
Colo Native wrote:Wild Card wrote:Colo Native wrote:
It is unbelievable that this went from finding the GREASE to bashing EZ Lube Axles. If anyone cares I did find that Lucas Red and Tacky is OK. That what I started this thread about GREASE!
Well, ya have to get everybodies opionion about the weather, current affairs and politics 1st.
We have covered which grease gun to use, where to put it, who doesnt like the system and 5 different methods of bearing maintenance.
In the end you answered your own question. Which I was going to help you with last night but the thread got ao derailed I just popped some popcorn , opened a beer and sat back for the entertainment. Sorry for that bit it was like a train wreck.
I know what you mean sometimes you just never know where these things are going, but I have resolved my issue and will be buying Lucas red and tacky at Autozone by my house and will use a grease gun per Dexter
โMar-09-2017 04:03 AM
components.
โMar-08-2017 01:08 PM
Do it whichever way you want too, it's your trailer, but on my trailers EZ lubes aren't a maintenance replacement for disassembling & inspection of bearings, races, spindles, brakes, magnets and other hub components.
โMar-08-2017 12:19 PM
โMar-08-2017 12:18 PM
โMar-08-2017 09:31 AM
โMar-08-2017 08:34 AM
โMar-08-2017 07:56 AM
โMar-08-2017 06:35 AM
โMar-08-2017 06:30 AM
fj12ryder wrote:
Ain't gonna happen. I am not pulling and repacking all of my six wheels at least every other year. I use the EZ Lube system and have had no issues in 5 years and maybe 20,000 miles. I pulled the wheels for the first time last year and everything looked fine. Good enough for me.
โMar-08-2017 06:27 AM
avvidclif1 wrote:
Bmach
If you pump enough to force the old grease out where does it go???
โMar-08-2017 06:07 AM
โMar-07-2017 09:39 PM
โMar-07-2017 05:00 PM
Cummins12V98 wrote:tragusa3 wrote:
Thanks for the tip on warm temps. How long do you think I need to tow to have the bearings warm? A few miles?
Leave the grease gun in the Sun for a while.
