Digital Thermostat Questions
Poppy_s_5th_Whe
Has anyone changed out their OEM digital thermostat?
My unit has an Atwood A/C and furnace and are controlled by an Atwood controller but it will only allow a low setting of 60 degrees. I would like to be able to set it as low as 45 or 50.
I contacted Atwood and they said they make them that way on purpose and there was no work around. They also said I wouldn't be able to use another brand thermostat but I think that may have been "the party line" which I understand.
This isn't rocket science right? It's just a matter of sending a signal, right? You can change out home thermostats no matter what brand furnace or A/C unit you may have so why not in an RV?
I am looking for your thoughts and or experience in doing this.
Thanks
Paul "Poppy" Cervone
2016 GMC Summit White Denali 3500HD SRW CC/SB
2015 Grand Design Reflection 337 RLS
6 REPLIES 6
Tachdriver
I replaced mine with a Honeywell digital system. What is nice is that you can set a temperature and leave it. When I leave the trailer to go hiking or beach I set the temperature higher, when I go to bed I have a favorite setting.
The older OEM slide seemed that I could never go to bed and have the temp where I wanted it.
If you change it out, be sure you take a photo of the older installation of the wiring incase you have to reinstall the old one. I have a Dometic.
Fabguy
This is what I did on our old trailer. Even used the same thermostat.
Hunter Thermostat install.
Jeff
2002 GMC Sierra 2500HD 8.1/Allison/4:10/Prodigy brake controler/Pullrite Superglide
Pulling a 2015 Keystone Cougar 280RLS
Ark235B
http://www.makariosrv.com/coleman-digital-wall-thermostat-8330-3362/
It will set anywhere you want it.
Justin Holder
2004.5 Dodge Ram 2500 Quad Cab SWB "600" Cummins
2010 Coachmen Chaparral Lite 270RKS Fifth Wheel
PPSEL
Poppy_s_5th_Whe
Mandalay Parr wrote:
My RV system is quite different than my home system. Thermostats are Niot interchangeable.
My thermo feeds a circuit board that controls both the heat and AC. Much different than home.
Yeah, that was basically what Atwood said.
Thanks
Mandalay_Parr
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
2oldman
One post of many on digital thermostats.
Search 'thermostat' in topic subject.
