Do I need air bags on my 2016 F350?
NorthernNeck_VA
I bought a 2016 F350 over the weekend to replace my 05 F350. On my 05 I installed air bags. I am wondering if I will need to install them on the 2016. I am pulling a 41 foot Landmark San Antiono.
Thoughts??
Thanks.
NNK
Jimmy & Kathy
Northern Neck, VA.
2013 Landmark San Antonio
2016 F350
2005 Ford F350, DRW, Diesel (SOLD)
2005 King of the Road "Royal Villa" 34BW (SOLD)
"The amateur does it 'til he gets it right. But the expert does it until he can't get it wrong."
36 REPLIES 36
justme
I have F350 SRW 2012 diesel truck with all of Ford's heavy duty stock suspension options pulling a 2012 Landmark. NO problems. The truck sits level and all the Ford specs are meet except Combined weight- which is 200 lbs over according to Cat Scale. I have pulled the trailer coast to coast and border to border including Canada with an accumulated 70,000 pulling miles. Never felt unsafe and the truck handles the trailer very well with decent fuel millage.
FishOnOne
Cummins12V98 wrote:
FishOnOne wrote:
Cummins12V98 wrote:
If you needed them on your 05 you will need them on your 16. Same rear suspension. 2017 is when they stepped up.
Wrong....
OK, just cuz u r DaFish does not mean you can get away with "WRONG"
Differences:
Spring length
Spring width
Spring thickness
Spring quantity
Different gap from overload spring to frame bumps
Different sway bar and mounting
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
ToddD
N-Trouble wrote:
Also consider Timbrens. I have used bags in the past and like them but Im also liking these Timbrens on my current truck. Something to be said about the simplicity, $, and ease of install.
Speaking of Timbrens, how's ride quality when fully loaded? My dually is within pin weight spec, and sits level, but squats a lot with big highway dips.
Todd
2018 Jayco 377RLBH
2019 Ford F-450 Platinum
nremtp143
G-Dad wrote:
I also have a VIAIR compressor/tank unit in my truck. What control system did you use to interface the air bags to your air system?
This dual pneumatic gauge from Firestone. It comes in both black and white faces.
Firestone Pneumatic Gauge
2016 Montana 3790RD, Legacy Edition, G614s, TST TPMS
2008 Thor Vortex 26FS
2013 F350 DRW 6.7L 4x4, Edge CTS, B&W Companion, Viair 10007 Air System, Firestone Air Bags
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
N-Trouble
old guy wrote:
hook up and see how level the truck stands. let that be your answer
^^THIS^^
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Cummins12V98
Garry&Gayle wrote:
I carry 4300# pin weight on a 15 F350 DRW, I can get by without air bags but 40psi in the bags improves the ride.
I had 4,500# pin on my 11 HO Dually RAM. It did NOT need bags but 30psi loaded and new Bilstein's made a huge difference on same roads compared to without.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
G-Dad
nremtp143 wrote:
G-Dad wrote:
I have the same truck with about 3K pin weight from my fiver. Good roads all OK. Bad roads, potholes and hard bridge expansion joints not so good. Thinking seriously about adding some sort of rear suspension assist.
Part of the reason why my last tow SDs have had airbags on them. Plus, it took away the "launch shudder" that some of them have. Another plus is that I put in an onboard air system with pneumatic controls so I can change the pressures in the bags when the road conditions change.
JIMNLIN
Good post.
Lots of guessing here. Load 'er all up and make a run down the road.....then decide if any suspension help is needed.
Garry_Gayle
Cummins12V98
FishOnOne wrote:
Wrong....
FishOnOne
Wrong....
Me_Again
What he said^^^^^!
Cummins12V98
azdryheat wrote:
My Voltage has 3500# on the pin and I haven't found the need for bags.
That is not a lot of pin. I am sure you would not need bags even at 4,500#. The last generation of Fords seemed to need bags more than GM or RAM.
Lwiddis
I disagree! A brand new truck, a 350, and OP thinks air bags may be needed? Why isnโ€™t the same as buying a Ram 1500 and trying to tow a โ€œway too bigโ€ TT? OP bought an inadequate truck.
nremtp143
