Jun-03-2013 04:21 AM
Jun-05-2013 07:04 PM
Jun-05-2013 08:35 AM
Jun-05-2013 05:25 AM
Jun-04-2013 03:57 AM
Jun-04-2013 03:35 AM
Jun-03-2013 07:57 PM
Jun-03-2013 02:52 PM
Jun-03-2013 02:31 PM
Jun-03-2013 02:23 PM
Jun-03-2013 02:01 PM
Jun-03-2013 10:54 AM
smkettner wrote:
The amp draw s/b close to 3 amps per wheel. Have you measured it? Either high or low is bad.
I assume you are experienced in drum brakes? Might be best to have a second experienced person help inspect the braking action one at a time.
Could be the shoes need to wear in a bit and this could take some time if the drums were not turned.
Jun-03-2013 09:52 AM
Jun-03-2013 09:37 AM
Jun-03-2013 08:25 AM
LarryDSLA wrote:
I recently changed the brake pads (12" X 2" 6K Axles) on my 2007 Cedar Creek Fifth Wheel trailer and adjusted as per manufacturer recommendations but the brakes are now week.
I have approximately 50% of braking capacity that I had prior to the change of pads.
I tried listening for the magnets pulling into the inner drums but only heard humming at each wheel. ...
the magnets actually engaging with the drums
1) I re-inspected and compared before and after photos taken in the duration of this task to verify all parts were re-installed correctly.
2) I re-adjusted the tension (more drag) on the brakes but I am not comfortable with the latest adjustment but it did increase braking slightly
