โMar-22-2014 09:55 PM
โMar-24-2014 12:28 PM
ah64id wrote:
What if the 250/350 uses the same axle? It does, BTW.
โMar-23-2014 06:31 PM
โMar-23-2014 06:17 PM
jpjulian wrote:
I was a weight cop for the state police for a long time so am very conscious of the various weight issues.
โMar-23-2014 05:58 PM
jpjulian wrote:
OOps...forgot. As the original question asked. Those of you who have 2013-14 F-350s, what is your rear axle weight rating?
Joe
โMar-23-2014 05:37 PM
โMar-23-2014 05:32 PM
spud1957 wrote:bpounds wrote:
You would be trading up to an F350 and getting the exact same Ford Sterling 10.5" rear axle.
Just keep your truck and check your wheels/tires. Upgrade those if needed.
X2!!!
OP, you haven't said what your current tires are. If they are 18s then you are good to go.
โMar-23-2014 03:55 PM
โMar-23-2014 03:41 PM
โMar-23-2014 01:57 PM
rhagfo wrote:
this may be a bit of the pot to the kettle, as I tow over GVWR, but I do respect axle ratings. I will agree that most 250/2500 have axle rating based on tires, but a 17,500# 5er on 250/2500 running gear is looking for trouble.
Winged One wrote:
Yes, I do. Sorry, unfortunately, I can't tell you. Don't remember. Haven't driven the truck since October/November and won't for another few weeks.
โMar-23-2014 01:48 PM
Atom Ant wrote:Winged One wrote:ah64id wrote:
As you can see the trans ratio is very important, and probably why Ford doesn't offer a 3.73 or 4.10 in the 250/350 pickups anymore. They have chosen to do most of their gearing reduction in the trans.
Except that they do. 3.73 and 4.30 in the DRW. Or did you mean just in the SRW? Though you can get a gasser with those gears in a SRW.
Do you have the 3.73? If so what RPM are you turning at 75 mph?
If I'm supposed to have 18% taller gears than you in final drive, it sure doesn't show up on the mpg. You 6.7 guys are doing far better.
โMar-23-2014 01:29 PM
KD4UPL wrote:
The RAWR of your current truck is likely based on the tires if it's only 6,100 pounds. Upgrading to higher rated tires (and wheels if necessary) should make the existing truck capable of your trailer.
โMar-23-2014 11:11 AM
โMar-23-2014 10:51 AM
โMar-23-2014 09:44 AM
โMar-23-2014 09:03 AM
