Ford F-350 hitch adapter kit uncertainty
madeenr_m
I recently purchased a used new truck, 2015 F-350 to tow my Lakota 5th. The Husky slider 16K in my old truck was a rail attachment hitch. I have found a Ford part whose nomenclature is
5th Wheel Rail Mount Adaptor Kit PN: BC3Z19H282A. This device looks like it marries to the built in attachment points in the F 350 SD bed. However, when cross referencing the PN to VIN, I get told by the Ford website that this part is not compatible with my VIN. I don't want to buy a new hitch if the old/serviceable one can be use on the new truck.
I live aways away from an RV dealership or reliable Ford dealer so I can't just drive down and verify. Wondering if any Forum readers have experience with this adapaptor kit issue.
Ron M.
12 REPLIES 12
cummins2014
rhagfo wrote:
MFL wrote:
Cummins12V98 wrote:
With the adapter you are simply throwing good money after bad!
Above is true. Some things to consider...Using an adapter raises hitch height. Depending on fit, can be a more movement/clunking. Do you really need a sliding hitch? A B&W 3300 for Ford (non-slider) fits the pucks directly, and is light wt...2 pieces 75 lbs/78 lbs. A direct fit slider is also available, but heavier.
If you save the $400, not buying adapter, sell the current hitch, you'll only be about $400 from a quality direct fit hitch. I know, it is easy to spend other peoples money, and if wanting to keep current hitch, it will work with one of the adapters.
Enjoy that new to you truck!
Jerry
Well in my case it was about $600 to $700 if I sold the Reese and skipped the adapter, and bought a B&W for the puck system. It is on the list, but had other short term needs for those $$$$.
So a $300 Reese adapter, and the old Reese hitch, well it all worked out great! The new 2016 bed is deeper, the adapter covered that and about 1/2" of extra rail clearance.
They do work out great, in all honesty , what have you given up not spending that 6-7 hundred. As said I did what you did 5 years ago, and can't think of a thing I would do different .
The first thing I thought of was could I use my existing hitch, and after a bit of research the adapter showed up .
cummins2014
Ron Ron Ron, The op has a hitch that he likes , the adapter is a great way to go. There are hitches in this world that work well , not everyone needs ,nor wants a B&W. I have an 18K Reese Signature ,same head as the Elite, has worked flawlessly for going on 12 years, five of those years sitting on the Reese adapter.
Now the OP can go to a hitch with the puck system, thats is also a great way to go, and he may not be aware, but if he is, its apparent he is happy with his existing hitch , then as said the adapter is a great way to go, There is a reason they build them .
rhagfo
Jerry
cummins2014
Me Again wrote:
Here is a better Demco picture frame adapter. Rated to 25K vs 20K for the one above and sits down closer to bed floor, which in many cases is important for leveling the hitch/pin box/trailer.
https://tweetys.com/demco-6175-ford-factory-fifth-wheel-oe-prep-package-isr-adapter-bracket-25k.aspx...
I can not find the height measurement for the Demco one, however the other one above is listed as 3". I believe that the Demco one is 1.5-2" above the bed. I have the RAM Demco one.Chris
I am sure the Demco is a great adapter, I have the Reese,,and IMO is equal , and its the same weight rating 25K, and sits 2" above the bed. The Reese adapter as you said for the ford is 3", and could be a factor ,although we are talking 1", and the 20K rating , if that is an issue, and thats a big if .
Reese adapters are as solid as any ,have used mine now for 5years. Not sure why such a price difference Demco for that ford is 467.95, Reese is 298.80 ,both from Tweety's . Free shipping
That is 169.15 difference in price, there isn't 15 cents difference in them , other then if as said the 25K rating is needed .
Just having an adapter, and only one brand the Reese, I see no reason for spending more on it then needed .
cummins2014
Jerry
The adapter has no movement , or clunking, if so there is adjustment , granted there could be some movement in the hitch , itโ€™s the same as mounting the hitch on bed rails. But the adapter is solid.
I went with the Reese adapter on my Ram to use my existing 18k Reese hitch. Itโ€™s far
from throwing good money after bad. If the OP has a hitch he likes the adapter is a great way to go.
MFL
Nomad II
Nomad II
Jerry
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Me_Again
Gearitis
I have a Husky 16k hitch and a 2015 F-350 with the Adaper that Old-Biscuit shows previous. Works like a charm, my rig is level. Easy in, easy out. Just made a 1500 mile trip to Big Bend, not a problem. I actually have been using this adapter in my previous 250 and moved it to this 350. Total miles pulling with the adapter is well over 15k. I would do it again if needed.
2015 F-350 King Ranch
2015 Sabre Silhouette Select 312RKDS
Cummins12V98
Do your self a favor and sell what you have instead of buying an adapter and then buy a B&W puck hitch. You will thank me!
Old-Biscuit
Ford Adapter Frame
Nv_Guy
Rather than dealing with the Ford parts world.
This is what I have:
Reese Elite Series Underbed Rail Adapter for Standard 5th Wheel Trailer Hitches - 20,000 lbs
Item # RP30156
This has the cams that attach to the underbed system, then your hitch drops into the slots on the top.
Image wouldn't post for me...
