Fresh water flows out of City connection
donajohn
Suddenly, when I run my water pump for using on-board water, the water spews out of the city connection. What's that all about? Didn't happen yesterday when I used it.
I have a Shurflo 4008-101-E65 rated at 55 psi. It replaced a 40 psi pump.
Is there some sort of back-flow preventer that's not preventing backflow through the system?
8 REPLIES 8
bob213
If you want to try and repair it this might help:
inlet valve repair
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
Learjet
Camco water shut off...works great..link......
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
Dick_B
This seems to be a common problem this time of year. I seem to remember several posts on this same subject.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Gsturner
Yup. I've frozen two of those out. Plug/cap it until you're ready to replace it and you're good to go and enjoy Spring.
SKP 115048
2016 Winnebago View 24M
2015 Harley Heritage Softail as toad
Retired:
2007 Titan LE with the Big Tow Package
2010 Rockwood 8315BSS
2008 Suzuki GZ 250-Response to 3/4 Life Crisis :C
Wrong_Lane
The screw in plug to block water from exiting the fitting is available at any store that sells RV supplies, Walmart has them for about $1.00. They even come with a lanyard to attach to your RV so the plug will not get lost.
The replacement valve is under $20.00. You need to look at the way your current one is connected as the replacement valves are available for connecting to both male and female fittings. You need to know which you need.
It's an easy fix.
2006 Damon Challenger 348F Ford V10
2013 Ford Taurus SEL AWD
Blue Ox Aventa & Brake Buddy
donajohn
Thanks to you all. I'll look into fixing it, but for now it's easiest to buy a plug...though I like that garden hose shutoff idea.
Old-Biscuit
YEP........inside the city water connection is a plunger/spring/o-ring assembly (check valve)
Remove screened washer and then with pressure relieved (open faucet cold side) you can try to reset by pushing in on tip of plunger....sometimes that works.
Sometimes the o-ring gets dislodged and then you have to remove city water connection from side of rig, disconnect plumbing line and then disassemble to fix.
I hate them cause they are cheap plastic junk.
I installed a garden hose 90* and then a garden hose shut-off valve.
They stay connected to connection on side of my 5vr (same set up on black tank flush)
Valve closed....when using pump
Valve open when using hose
DONE!
You can also just screw in a 3/4" PVC plug when using pump
kaydeejay
Exactly what it is. If you are lucky you may be able to reseat the sprung seal from outside, otherwise the inlet needs replacing.
Not a huge or expensive job - just a PITA!
Keith J.
Sold the fiver and looking for a DP, but not in any hurry right now.
