Thanks All,
And to the moderator I apologize for the new thread, and will focus on not repeating. The fridge is a RF18 HFEN , Samsung, and the inverter made by a Canadian co. WFCO, the model is WF5110H.
The main breaker panel has nothing marked fridge, just two 50amp main,bedrm,micro,kitchen GFI,living,vac.,AC, kit2, washer,water heater,dryer,converter and another AC. The kit2 label is hand written as is all the fuses,the rest are printed. Am I to assume the hand written are dealer and printed Manuf. As for the Pug it is visible through a small gap on side of fridge but the only way I could get to it is unbolt fridge mount brackets. I'm no expert on elec. but I'm decent and can read schematics, but with out one, as you all know it's a little harder. The inverter mentions nothing about charging,nor does it show or mention the power cord. The way it is mounted (front towards rear of fifth in pass through storage comp.) it is hard to read and the receptacle I mentioned is wedged against frame and inverter. Thanks again
