โMay-22-2017 04:25 PM
โJul-15-2017 11:27 AM
โJul-15-2017 06:33 AM
โMay-23-2017 02:48 PM
โMay-23-2017 09:47 AM
allcool wrote:coolbreeze01 wrote:
Green light comes on, fuse isn't blown, but the pump doesn't work.
No noise, nothing.
Ideas appreciated.
1) Go directly to pump. Check Directly AT pump, not at switch or fuse or any other place, with a volt meter check for 12v at pump. If no 12v at pump, disconnect trailer wires and use jumper wires to supply 12v directly to pump.
2)If 12v is present directly at pump, and pump runs, check wiring/switch/fuse/fuse holder/timer/etc.
3)If 12v is present directly at pump, and pump does not run, carefully disconnect and take out pump.
4)Remove pump cover plate to expose gears. Take out gears and then apply 12volts to pump. If pump motor runs, its the gears. If pump does not run, its the pump motor.
5) Repair and or replace as needed...
jmo
โMay-23-2017 09:30 AM
โMay-23-2017 09:25 AM
No noise, nothing.
Ideas appreciated.
โMay-22-2017 07:54 PM
โMay-22-2017 06:58 PM
