generator storage
MainerBob
Just got a Yamaha 2000is and have it in the bed of the pickup. Of course I would never use it in the trailer but is it sealed well enough to carry it in a basement storage compartment? The gas cap seals when not running and I can always shut off the fuel and run it dry. Concern is gas fumes in the basement. I also have the front storage where the jack motor is.
2007 Keystone Everest 293P, 32'
2006 Silvarado 2500HD Duramax, SRW, CC, Short Bed, 4x4
Sidewinder,16K Draw-Tite Slider
Chloe, Standard Poodle
Charlie, Tibetan Terrier
5 REPLIES 5
RustyJC
I have sufficient room in the QuickDraw pullout tray in the basement to store both of my Yamaha EF2000iS generators side-by-side when they're not in use. With the gas caps sealed when in the "off" position, fumes aren't a problem.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
jalichty
I put both my Hondas in the front storage compartment of my FW, plus some other stuff. Only problem I have is getting them out when I'm feeling weak, that lip is a little too high for me. Have to pick up the gen in both arms to lift over the lip, just using the grip handle on the top is a little bit much for me. However, when I get it in, I make sure the gas cap is switched to off so no fumes leak out, and so far, no gas smell.
John A. Lichty
Itching2go
Same with the Champion 2000i. Gas cap has a lock that seals it, so no fumes there. We just make sure to shut off the fuel and run the carb dry before stowing away. Never had a problem.
2008 Jayco Designer 35RLSA pulled by a 2007 Chevy 3500 D/A SRW
Oasisbob
Yes, it is made for this. We put our Honda EU in the bathroom while traveling.
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS:)
2oldman
Yes, that's fine. Do it all the time with my Honda. I do get gas smell from time to time, but that's from the accumulation of gas drips when filling. Sometimes I'll cover it with a large garbage bag until I can thoroughly clean it.
