โAug-06-2013 05:08 PM
โOct-18-2013 05:47 PM
MrVan wrote:JEBar wrote:MrVan wrote:
That is absolutely amazing. Three failures and still using the same tire size, model and brand? Why not buy a tire that doesn't fail?
OK, give me the name of a brand that is guaranteed to never fail .... wait a moment I'll make it a bit easier, give me the name of a brand that is guaranteed not to fail for 5 years of use with little, if any, regard for miles of use and I'll give it serious consideration .... my bet is you can't do so, nor can anyone else because that tire doesn't exist .... until it does, I'll stick with the only one that will pay for the damage .... as others have noted, the failures we experienced were years ago, as best I can remember the last one was back in '06 or '07
Jim
I'm not aware of any tire manufacturer that will guarantee a tire not to fail but there have been many RV.net members who have switched tires types/brands after failures and have not had any more failures. Seems to me that would indicate something that would cause any RV.net member to give serious consideration to changing tire brands/type after experiencing 3 tire failures which also caused major RV damage. After owning a 5th wheel for 6 years, if and when we ever purchase another, the consideration of the warranty provided by the manufacturer will be a distant second to the manufacturer who requires the least amount of warranty repairs. Warranty repairs are not free and in fact are a real hassle.
โOct-18-2013 03:10 PM
โOct-18-2013 10:52 AM
โOct-18-2013 10:31 AM
fj12ryder wrote:Read my post on page # 5. Sailon tires. My rig has 7K axlesggmac wrote:Yes there are.
Hello
Are there any 16" LT tires out there besides the Goodyear 616 that has the
capacity to use on 7000lb axles?
โOct-18-2013 10:04 AM
Hello
โOct-18-2013 09:54 AM
โOct-18-2013 06:02 AM
thecampingman wrote:
Which Sailuns tire are you talking about?
I looked at the website and the S637 doesn't come in LT235/85R16G size. The smallest rim for this tire is 17.5".
In fact the only G rated 16" tire I found was a lugged dump truck tire with a max speed rating of 70mph.
Could someone post a link to the tire in discussion?
โOct-18-2013 05:41 AM
โOct-17-2013 11:56 PM
reddwar wrote:
Well I have never heard of the Sailin 637 tire. Our 04 HH came with GY G614 the sorriest tires I ever had what did not blow up only lasted 40,000 miles. So I started looking around for a different tire the GY G614 was the only G rated tire out there so after first blow up got a new one. Had another blow out but it took out the valve stem on other tire so I needed two tires. Called GS road service first guy wanted to give me E tires I said no. GS called #2 he would not get me a G614 either but he said on the logging were using the hankook F19 750r16 a 14ply same as G tire & they had good luck with them - it was take them or set there. I liked them & ended up put F19 on the other side. When I traded off our rig had 50,000 miles on the first two tires & they still looked like new great tires. Next time you are in a big truck stop look around at all the hankook tires on big rigs. I am replacing the tires on my 07 3500 Mega cab drw rwd Dodge. I could only find two tires with a 70,000 mile rating michelin & hankook in a LT235/80R17. With hankook tires I can save $400. Like I said earlier Look at all the hankook tires on big rigs if they did not make good tires they would not run them. So if you need to replace your GY G614 you may want to look at the hankook F19 750r16. Oh yes always have them balance all tires even on your rig. Our new rig has 17.5's
red
โOct-17-2013 11:54 PM
โOct-17-2013 09:55 PM
Jim
โOct-17-2013 08:27 PM
Jim
โOct-17-2013 08:23 PM
โOct-17-2013 07:33 PM
Jim
โOct-17-2013 07:10 PM
